Wireless charging upgrade, need info
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ktbell444, Aug 8, 2017.
  1. Oct 27, 2020 at 5:55 PM
    #41
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Yes, this. I can usually get 10-20% on a slow charge before the battery gets too hot and the phone cuts off charging.
    ktbell444[QUOTED][OP] likes this.
  2. Oct 28, 2020 at 6:16 AM
    #42
    TA-5650
    TA-5650 Well-Known Member
    Wilmington, DE
    2017 TRD OR DCSB, Blazing Blue Pearl
    gotta take a look at the power draw, but there should be a way to replace the coil. I’ll ask my electrical engineer buddy.
    RedWings44[QUOTED] likes this.
  3. Oct 28, 2020 at 6:21 AM
    #43
    ktbell444
    ktbell444 [OP] One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    It's doable but takes quite a bit of modification (replace the guts with a COTS fast wireless charger). The issue I ran into was the heat dissipation.
    RedWings44 likes this.
  4. Oct 28, 2020 at 6:47 AM
    #44
    RedWings44
    Michigan
    At the end of the day I just saw a lot of "solutions" such as someone velcroing a Samsung charger in the wireless charging spot and I definitely don't like those ideas.
    ktbell444[OP] likes this.
  5. Oct 28, 2020 at 6:48 AM
    #45
    RedWings44
    Michigan
    Did you try drilling any low profile holes in the trim to help?
  6. Oct 28, 2020 at 11:34 AM
    #46
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    Post #26, lol
  7. Oct 28, 2020 at 11:44 AM
    #47
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    I'm wondering if it might be possible to employ some cpu heatsink principles? Perhaps there is some way to attach a large aluminum block to the underside of the replacement charger / coil which can both readily absorb heat and also potentially transfer it to the vehicle chassis or a set of radiator fins with large surface area to radiate heat over a larger area? Similar to how heat pipes take heat off a CPU and into the fins which then distribute the heat to the environment keeping the CPU itself at a controlled temp?
    That sounds like a rather complicated piece to machine though and seems likely that the resulting temp of the pad would still exceed the range desired.
    BSFord likes this.
  8. Oct 28, 2020 at 11:52 AM
    #48
    BSFord
    BSFord Well-Known Member
    2018 TRD Sport 4x4
    Clazzio PVC Seat Covers Dashcam install TRD Pro Grill MESO Total Tail Stage 1 Tailgate Lock vled total interior light upgrade TRD Pro Shift knob N2 Designs Autostart w/ smart phone module
    I'd be in for that mod. Mine works and charges my phone fine, but I agree it would've been nice if Toyota used a newer fast charger and implemented cooling in the stock configuration, it would've been so easy to add a A/C vent there for example.
  9. Oct 28, 2020 at 12:16 PM
    #49
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    Yeah, I'd have my doubts.
    I considered that, but during winter or cold days you'd be blasting heat directly at it.
  10. Oct 28, 2020 at 12:44 PM
    #50
    N8Dizzle
    N8Dizzle Well-Known Member
    Nate
    Sumner
    2020 AG TRD PRO MT
    Cooper S/T Maxx 255/85/16
    How are you guys texting and driving with the phone way down there? :rofl:It seems more dangerous.
    TA-5650, ktbell444[OP] and daveeasa like this.
  11. Oct 28, 2020 at 1:30 PM
    #51
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    I drive an automatic so only one foot is tied up while driving.:cool:
  12. Oct 28, 2020 at 1:33 PM
    #52
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Cheaper route is just to plug it in there is a usb plug there .. oO
    N8Dizzle likes this.
  13. Oct 28, 2020 at 3:11 PM
    #53
    RedWings44
    Michigan
    I wasn't thinking as much as adding a computer fan, but maybe a way to draw some airflow. One hole on the bottom and one up top, maybe.
  14. Oct 28, 2020 at 3:17 PM
    #54
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    I'm not sure stagnant air would be efficient. If it were then ambient air around modern wireless chargers inside of your home would be enough (in theory). If a peltier didn't create so much ice I would go that route. One idea would be to design the complete base with an air intake and an exhaust to keep the fan hidden. The 3D printed vents would show though. That and the 3D printed base that will look nothing like OEM.
  15. Oct 28, 2020 at 3:36 PM
    #55
    RedWings44
    Michigan
    Well, I was thinking since the Samsung charger has a built in fan (so I'm told), it would move things around. That or you place a fan inside, where it can't be seen, and let that move the air around via the low profile holes.
  16. Oct 28, 2020 at 3:40 PM
    #56
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    Yeah, the idea was to replace the OEM wireless charging unit completely. Maybe if I have time I can draft it up and print out a model. Working full time and attending school full time kind of keeps me from taking on long projects. Should have a break in about 2 months though.
    TA-5650 and daveeasa like this.
  17. Oct 28, 2020 at 3:54 PM
    #57
    RedWings44
    Michigan
    I'm looking forward to seeing what you can come up with
