Wireless phone charger to hot?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoTimothy, Apr 19, 2021.
  1. Apr 19, 2021 at 1:46 AM
    TacoTimothy
    TacoTimothy [OP] Member
    2019 Sport Tacoma
    I have the Qi wireless phone charger in my truck,, but I noticed that it really makes my phone hot when charging, my home charger doesn't do this, so is this natural for the Toyota or is there something wrong with mine?
  2. Apr 19, 2021 at 3:01 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Normal. It has to do with the inability to dissipate heat properly. It's not limited to Toyota, I don't believe. Several threads were dedicated to trying to make a better system, but ultimately no one was successful at making anything that looked OEM. It is more meant for charging for a short time anyway. Anything longer and it should be plugged in.
    Tacospike likes this.
  3. Apr 19, 2021 at 4:10 AM
    TacoTimothy
    2019 Sport Tacoma
    Ok.. good to know. I am just worried that it will kill my phone, electronics don't like heat ya know lol.. wondering if I could place a fan there somehow ,, I will really have to dig into that.
  4. Apr 19, 2021 at 4:58 AM
    RedWings44
    Michigan
    You probably could. I don't know how much good it would do since the battery is the main source of heat and that's on the bottom of the phone. In the winter I can usually get about a 10% charge without issues on my 45 minute commute. In the summer, I'm lucky if I get half that time before the phone is hotter than I feel comfortable. For the record, I'm never worried the battery will explode but, like you, I worry about the longevity of the battery. Also, since these are generic QI wireless chargers, they're not very fast even if properly ventilated. But that's by design.
  5. Apr 19, 2021 at 5:26 AM
    brich999
    brich999 Well-Known Member
    Bryan
    16 Tacoma TRD Sport AC
    all tore up already
    It will make a real weird alert beep noise and flash the green and orange lights when it gets too hot. At this point it stops charging
    WoodsGhost and Chew like this.
  6. Apr 19, 2021 at 8:58 AM
    tomgru
    tomgru Well-Known Member
    Thomas
    PNW
    2021 TRD Pro
    I have a case on mine with a small metal plate that alow me to attach phone to magnetic holder. If that sits near the charger it also seems to make it heat up faster. YMMV
  7. Apr 19, 2021 at 10:33 AM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    I like your profile picture
  8. Apr 19, 2021 at 10:33 AM
    RedWings44
    Michigan
    That's if you don't catch it before then. My phone will go into trickle charge mode if it gets too hot and pretty much maintain its current charge. That must be before what you described because I've not experienced that yet.
  9. Apr 19, 2021 at 12:19 PM
    TacoTimothy
    2019 Sport Tacoma
    Well this stinks... I was really excited when I found out I had this charger, but its not worth the risk of loosing my phone with it overheating everytime I wish to charge it. Of course I could probably charge it till I swap phones in a couple years and it never have an issue
    I will just stick with the plug to charge while I travel, my home wireless charger doesn't even get my phone warm so I know it's possible to charge without heating it,, would be nice if they came up with a fix or replacement .
  10. Apr 19, 2021 at 12:31 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    My phone is coming up on nearly four years of age. I charge it on the Qi pad without issue. Most road and day trips it will be between 4-5 hours of use before the overheat alarm goes off, and I've managed to set it off frequently.
    So far the phone battery is still going strong.
  11. Apr 19, 2021 at 2:19 PM
    RedWings44
    Michigan
    I should amend my last statement. A lot of heat comes from the charger itself as well. A lot of wireless chargers (particularly the fast ones) actually have fans built in. The main issue is lack of airflow. I haven't heard anyone try adding any holes to the sides of the console underneath the charger. You certainly shouldn't be afraid to use it though.
    Also, if you hit "quote" in the bottom right of the comment you're responding to, the person you're responding to will get a notification.
  12. Apr 19, 2021 at 2:31 PM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    Mine charges way faster than that. I wonder if the phone case plays into it.
    Rock Lobster likes this.
  13. Apr 19, 2021 at 2:50 PM
    RedWings44
    Michigan
    I was actually just coming here to add that. In general with wireless charging, cases make the charging more difficult so it is slower and creates more heat. It'll definitely be more efficient without the case. As a matter of fact, I just did that with my phone on my commute today. The phone charges faster although it did still produce some heat. But enough I was still comfortable with it.
    Thunder Fist[QUOTED] likes this.
  14. Apr 20, 2021 at 4:12 AM
    TacoTimothy
    2019 Sport Tacoma
    I was wondering about trying to remove my case,, I will be taking a long road trip next week and I will try it, I'll just test the temp after 30 minutes or so and keep an eye on it..
  15. Apr 20, 2021 at 4:45 AM
    ugawino
    ugawino Well-Known Member
    Bill
    Paola, KS
    2021 TRD Off-Road, Silver Sky Metallic
    Mods? We don't need no stinking mods.
    That Qi charger is trash. Even when it isn't cooking your phone, it's a really slooooow charge.
    Best to use a charger in the old cigarette lighter or better yet, take advantage of the most excellent Android Auto (or Apple Play) with a USB cable.
  16. Apr 20, 2021 at 5:18 AM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    I never put cases on my phones. Maybe that's why I dont have a complaint against the charger.
  17. Apr 20, 2021 at 6:45 AM
    slowlane
    slowlane Well-Known Member
    AZ
    16 double cab MGM
    In the az summer, the wireless charger is pretty much useless. Its so hot the phone gives me an error message saying the phone is overheating.
    NinGee87 likes this.
