Wireless Router Configuration
Discussion in 'Technology' started by AFButters, Oct 20, 2010.
  1. Oct 20, 2010 at 2:38 PM
    AFButters
    AFButters [OP] Rigger, Please!!
    "Butters"
    Albuquerque, NM
    2008 335xi BMW
    I got the new Netbook, and was havin issues hookin it upand being an idiot I pushed the reset button and now I can't figure out what settings I need to do so my DSL will work
    If I run a LAN or Wireless from the Router I get no Internet, but if I run from the modem wired into computer it works great
  2. Oct 20, 2010 at 2:39 PM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    Toytec TRD PRO LIFT with 1.5 SAW in rear, 255 Coopers, Baja Rack, Southern Style Front Bumper, Warn Wireless Winch, DeMello Sliders.
    My advice would be to unplug everything, modem and router. Then plug modem in first, let it boot, then plug in the router. They should connect back together again.
  3. Oct 20, 2010 at 2:47 PM
    ruler
    ruler Well-Known Member
    SoCal - Los Angeles - SGV
    08 Tacoma, TRD Sport, DC 4x4
    Fox Extended Travel Coilovers 2.5 (front), Fox 2.0 shocks (rear),Total Chaos UCA's, AllPro Expedition leaf pack, AllPro front plate style bumper,BHLM, GrillCraft MX series Grill, ATX Thug 17inch rims, Toyo Open Country MT (295,70,17), TRD CAI,Rear smoked LED tail lights, slimcubby HID Head Lights (50w 1200k), ADVMonster 60 Series 3600 Lumen LED Off Road Lights , Pioneer Avic-F700bt (navigation,head unit)
    if you get internet when your connected wired but not through the wireless then your wireless security settings aren't configured correctly. Connect the computer to the router through the wire, open your web browser and type in the routers IP Address (i.e 192.168.0.1) a box should pop up asking you to login , depending on the brand of router this next part may vary but usually the username is admin, and password is blank (if not sure visit your manufacturers website and download the manual for your specific device) it should give you the login information.
    Set your wireless security settings (wep/wpa/wpa2) choose a password , then search for your network on the laptop and it should prompt for the "key" also known as the password.
  4. Oct 20, 2010 at 3:19 PM
    wing103
    wing103 Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
    Log on to your router and check the PPPOE is it clicked, if you use verizon DSL. it will be PPPOE
    Hope this help
  5. Oct 20, 2010 at 3:19 PM
    AFButters
    "Butters"
    Albuquerque, NM
    2008 335xi BMW
    I have done all of this, and still nothing.... This shit is pissin me off, all of this stuff should just be plug and play
  6. Oct 20, 2010 at 4:17 PM
    wing103
    Boston
    Clone ip address from your router?
  7. Oct 20, 2010 at 4:23 PM
    03coma
    03coma Well-Known Member
    New Jersey
    2015 DCSB TRD, SR5
    TRD Pro Grille, Skid Plate, TRD Cat-Back Exhaust System, 2017 Tacoma TRD Rims, ARE Series II Lid,
    Hey dumb question for you, in the settings of your router, do you have a tab for wireless connection? if yes check to see if this is disabled. My Verizon router is defaulted to disabled, had to enable it for my laptop to work.
    Is the wireless light lit on your router?
