Wiring 6 18w lights on one switch question
Discussion in '1st Gen. Tacomas (1995-2004)' started by SilverlineShockService, Oct 13, 2015.
  1. Oct 13, 2015 at 9:09 AM
    SilverlineShockService [OP] Well-Known Member
    Austin
    Tehachapi,CA
    '16 DCLB OR Taco
    Just a quick question I got 6 18w led pods I want to wire on one carling switch how would I wire that? Do I need relays? Any ideas on how to wire it? Thanks
  2. Oct 13, 2015 at 9:26 AM
    Indy
    Indy Master of all I survey.
    Wire in parallel, just attach the grounds to the body. With LED's you should be fine running through the switch. The relay is the preferable route for most lighting, but at 5-6amps (72w at 12-14.4v) you're well withing what a basic switch can handle.
  3. Oct 13, 2015 at 9:36 AM
    Austin
    Tehachapi,CA
    '16 DCLB OR Taco
    Okay what gauge should the wire be when all the wires meet to one wire to the switch?
  4. Oct 13, 2015 at 9:52 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    18 watts x 6 = 108 watts. 108/13 volts= 8.3 amps. I would not run 9 amps through a switch in the cab. Use a relay mounted under the hood.
    ontarioyota likes this.
  5. Oct 13, 2015 at 9:55 AM
    RustyBlue
    RustyBlue Meh...
    Bryan
    Dayton, Ohio
    06 A-Cab TRD Off-Road 4x4
    Highly recommend a relay. Wiring to the switch is more simple and you can keep the higher gauge wire between the relay and the lights. When I get home today, I'll post the block diagram wiring schematic I made for my two light setup. You'd do the same but with 6 lights in parallel.
    18 w light isn't a lot of power. Each parallel branch will be running 1.5A. Depending on how you split the nodes, your max current is only 9A. 12 gauge wire is rated to 9.3A. You can go with 10 gauge to be safe, but only if you are having all lights branch from a single line (6*1.5A)
    Always match your ground gauge to the hot gauge.
  6. Oct 14, 2015 at 10:27 AM
    Indy
    Yep, 6 lights is 108w. I did the math on 4 for some reason. So between 9 and 7.5a (12v-14.4v) Most switches (read the package) are 20a or better. Still within safe for the switch, still a better option with a relay.
  7. Oct 14, 2015 at 5:35 PM
    RustyBlue
    RustyBlue Meh...
    Bryan
    Dayton, Ohio
    here's how i wired my BlitzPro Rocker Switch to my Off-Road lights. I put the switch in one of my dash switch blanks. There was an OEM female connector behind the blank that is used for a TRD Sport switch (i have an TRD OR). I used that connector's illumination wires to illuminate the rocker switch.
    Off-Road%20Light%20Switch%20Schematic_zp_9699ca9db8bb63893b0bb3a02a3a7422cf43155f.jpg
    Off-Road%20Light%20Schematic_zpsn1di5wwt_8c35d2cb1c43ba6195ca073f1275c13595e47c3b.jpg
