Wiring a Leer camper shell
Discussion in 'Tonneau Covers, Caps and Shells' started by Seskaf, Mar 7, 2011.
  1. Mar 7, 2011 at 6:12 PM
    Seskaf
    Seskaf [OP] Member
    Rob
    TN
    Just bought a leer 100r. It has a four prong connector to wire the dome and 3rd brake light. The problem is I dont know how to wire it up. Any help would be welcomed.
  2. Mar 7, 2011 at 6:15 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    if it has a 4 prong, then you just plug that into your trailer wiring.
    if your truck is wired for towing, yours will be a round 7 pin connection, and you'll need an adapter.
  3. Mar 7, 2011 at 8:32 PM
    gwheyduke
    gwheyduke New Member
    Denver Colorado
    08 TRD Sport
    I just did this yesterday. Here is what I did. Note I had the 7 pin trailer port so I had to tap into the wires.
    Purchase a 4 prong wire harness and some extra wire as the harness will likely not be long enough. You need about 5 feet of wire total. You can use water proof/heatshrink butt connectors to add wire to the harness. Remove the plastic side caps on the drivers side and feed the wire down the light cavity in the back. It may be easier to come out the 2" hole in the side of the cavity rather than trying to feed the wires all the way past the brake lights. Next, use a quick connect wire splice kit to tap into the wires on the 7 prong trailer port. On my 7 pin white was ground, brown was a tukrn signal, red was a turn signal and green was tail lights (I also had a cover over the port that indicated which of the 7 pins was what. I used that key to figure out the correct wires for the 4 pin adapter.) Be sure you splice into the wire a fair distance away from the 7 pin port as you won't be able to fit the plastic cover back on if you put all of them near the port. Finally, you can use liquid tape or electrical tape to cover it all up.
  4. Jun 13, 2011 at 8:12 AM
    testedone
    testedone Speak English..it's America
    Rick
    U.S.A.
    2010 Tacoma TRD Sport
    Weathertec Mats, Pioneer AVIC-X930BT, Pioneer GEX-P920XM (SAT), Pioneer Premier TS-D602P 6.2, Blaupunkt THb 200A Sub, Trimmed Mud Flaps, BF Goodrich AT/KO 285/70/17 ... Toytec Ultimate Lift, Tuffy Bed Box, A.R.E. Cover, Pop-n-Lock, TRD Exhaust
    This only gives power to the interior (of the shell) light when the truck is running correct?
  5. Jun 14, 2011 at 7:19 AM
    gwheyduke
    Denver Colorado
    08 TRD Sport
    It also provides power to the exterior brake light on my shell.
  6. Jun 14, 2011 at 1:01 PM
    testedone
    Rick
    U.S.A.
    is it switched?
  7. Jun 15, 2011 at 7:17 AM
    gwheyduke
    Denver Colorado
    08 TRD Sport
    Not that I am aware of.
  8. Jun 17, 2011 at 12:50 AM
    testedone
    Rick
    U.S.A.
    it is a switched power connection, meaning...when the truck is off there is no power...
