Wiring accessory 12v power outlet
Discussion in '2nd Gen. Tacomas (2005-2015)' started by moto77, Apr 7, 2012.
  1. Apr 7, 2012 at 5:05 PM
    moto77
    moto77 [OP] New Member
    Joe
    Bountiful, UT
    2008 Tacoma 4wd
    Does anyone know how to make the 12v accessory outlet located next to the lighter on my 2008 Tacoma hot all the time without removing the console and running a new wire?
    Thanks
  2. Apr 7, 2012 at 5:11 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    Yes, download the new software patch.
    No, It's hooked into a fuse block that's only on when the key is switched to ON.
    You'd have to wire it to the battery directly.
  3. Apr 7, 2012 at 10:04 PM
    joes06tacoma
    Joe
    Central Coast, CA
    There is a relay on the back side of the interior fuse block. Somewhere on here there is a writeup on how to remove the relay and bypass it.
    I've done it on a first gen, but that truck has it under the hood. 2nd gen is a little more work but looks doable. You still have to disassemble some stuff, but don't need to run a new wire.
