Wiring an Aux Fuse Block, Relays and Switches in a 2016
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Nov 15, 2015.
  1. Sep 3, 2016 at 6:44 PM
    #81
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    where did you get this template for the sunglass holder
  2. Sep 3, 2016 at 6:48 PM
    #82
    nevadabugle
    nevadabugle [OP] Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    I just used the plate that holds the switches and traced it's profile onto the door. Then cut it out with a Dremel. If you use the 6 switches like me measure thrice and cut once. There is not much room for error left or right.
    Joe23[QUOTED] likes this.
  3. Nov 14, 2016 at 3:44 PM
    #83
    michael042
    michael042 Member
    Michael
    SAN DIEGO
    EXPEDITION TACOMA
    To confirm, the connector for the electrical trailer brakes is behind the kick panel on the drivers side. The best way to tap into the trailer connector is to buy a trailer brake harness adapter for your year (link for 2006 below), plug it into the connector, and then tap into the wires of the adapter for power, etc. The OP mentioned that he didn't intend to use the trailer brake connector but it will still be usable for trailer brakes if you use tap connectors. It can be easily unplugged for troubleshooting or to avoid discussions with your Toyota dealer about warranty issues.
    https://www.amazon.com/gp/product/B001NZQIFM/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
  4. Nov 14, 2016 at 3:54 PM
    #84
    nevadabugle
    Elko, NV
    Great idea. thanks.
  5. Nov 18, 2016 at 3:48 PM
    #85
    coopsa111
    coopsa111 Well-Known Member
  6. Nov 18, 2016 at 8:17 PM
    #86
    Cazzwell
    Cazzwell The Circuit Rider Signman
    2018 Silver Sky DCSB TRD Sport
    Stock.
    Ill have to look into seeing if I can use one of these to tap 12v for my dashcam for now. I dont want to splice any wires for now since I lease it.
  7. Nov 18, 2016 at 8:27 PM
    #87
    0210
    0210 Well-Known Member
    Vancouver, BC
    2016 TRD Sport Upgrade DCLB
    There's a switched 12V fuse in the truck's main fuse box. Use a fuse tap - no cutting or splicing.
  8. Nov 18, 2016 at 8:40 PM
    #88
    Cazzwell
    Stock.
    I am trying to avoid using a fuse tap as I dont want to have to leave the cover off and the wires hanging down, or run a wire through the firewall for now.
  9. Nov 18, 2016 at 9:11 PM
    #89
    0210
    Vancouver, BC
    Why would you leave the cover off? I put mine back in place, with the tapped wire poking out from under it. Running a wire through the firewall is also easy - there are several spots you can poke it through without doing any damage.
  10. Nov 18, 2016 at 9:34 PM
    #90
    Cazzwell
    Stock.
    Id have to leave the (white) cover off/dangling if i used a mini wiretap in the box under the dash.
    I just cant wait until I buy out my lease. I plan on adding a 2nd battery/brake control/busbox/CB/ and upgrading said dashcam to 24hr system among other things.
    I would need this anyway if I get the brake contoller
  11. Nov 19, 2016 at 12:41 AM
    #91
    Santanero714
    Santanero714 Well-Known Member
  12. Nov 19, 2016 at 1:52 PM
    #92
    0210
    Vancouver, BC
    Hey @nevadabugle - do you know the manufacturer of that plastic container? Or where I can get one?
  13. Nov 19, 2016 at 2:26 PM
    #93
    nevadabugle
    Elko, NV
    Husky. Home Depot . I think there was a link for then posted farther up in the thread.
    0210 likes this.
  14. Nov 19, 2016 at 2:42 PM
    #94
    0210
    Vancouver, BC
    Great. Thank you!
  15. Nov 30, 2016 at 1:18 AM
    #95
    Toyota Kawasaki
    Toyota Kawasaki Seasons Beatings
    2016 TRD OR
    If your going to keep the truck and pay the lease residual, why wait?? I doubt anyone will ever notice where a wire "was" if you decide not to keep the vehicle anyway.. Been there, done that.. Many many years ago.
  16. Nov 30, 2016 at 10:59 AM
    #96
    i8boots
    i8boots Well-Known Member
    UT - 801
    2017 MGM DC SB TRDOR JBL
    Hood/bed lights, pop-n-lock, RSI EvoA, fully custom fuse box, Husky mudflaps, white interior LEDs, Morimoto xB v2 Headlights, Bilstein 6112/5160, Sumo Springs, Meso puddle pods and overhead lights, anytime backup mod, light out in reverse mod, ac drain mod, Calirased CAT protectors, ARB Dual Air in bed.
    Does this thread need more pics? I used pretty much the same parts and made a box for myself. That strap is a game changer, seriously. I've even upgraded mine to add a ignition-controlled relay.
    Only problem I have is having to disconnect the power (unscrew bolts very carefully) every time I need to get into my actual fuse box. Hopefully this prevents any of those fuses /relays from blowing out.
  17. Dec 5, 2016 at 8:55 AM
    #97
    Harbormaster
    Harbormaster Active Member
    2016 Tacoma TRD Pro DCLB
    Where are the pos/neg wires running to from the 6th circuit if there are only 5 relays in your box? Just curious where those went.
  18. Dec 5, 2016 at 12:09 PM
    #98
    nevadabugle
    Elko, NV
    A
    At the moment they go nowhere. I figure when I have used all 5 of those relays I will mount the sixth near whatever component that 6th location will feed.
  19. Dec 5, 2016 at 12:34 PM
    #99
    Joe23
    nevada gets snow?
    Seriously thought it was all a desert...
  20. Dec 5, 2016 at 12:38 PM
    #100
    nevadabugle
    Elko, NV
    Ha! We call that Vegas syndrome. The whole world pictures Nevada as being just like Vegas. Most of Nevada gets lots of snow and cold. We see 25 below every winter and I shovel and plow more snow than I care to admit.
