Wiring an Aux Fuse Block, Relays and Switches in a 2016
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Nov 15, 2015.
  1. Dec 5, 2016 at 12:42 PM
    #101
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    guess thats like many think all of us up here in the north live in igloos and speak french lol.
    or say 'aboot' instead of about.
    didn't think you guys were far enough north though for snow, but I guess being inland changes things
    69TACO16 likes this.
  2. Dec 5, 2016 at 12:45 PM
    #102
    Cazzwell
    Cazzwell The Circuit Rider Signman
    2018 Silver Sky DCSB TRD Sport
    Stock.
  3. Dec 5, 2016 at 12:47 PM
    #103
    Joe23
    nevadabugle[OP] likes this.
  4. Dec 23, 2016 at 2:50 PM
    #104
    TWTaco
    TWTaco Well-Known Member
    Dave
    Yes add whatever photos you have would be a great help for me!
    Marbleyard likes this.
  5. Dec 23, 2016 at 3:01 PM
    #105
    TWTaco
    Dave
    I will be running 4 switches , can you tap all 4 into the brake control harness?
  6. Dec 23, 2016 at 3:12 PM
    #106
    0210
    0210 Well-Known Member
    Vancouver, BC
    2016 TRD Sport Upgrade DCLB
    ^ Timely thread bump!
    I used the same 11" Husky box as OP and came up with this just the other day:
    Both of the circuit breakers will receive power through the same connection in the bottom-left corner of the box. The top circuit breaker feeds a wire that goes to the back of the bed, which has its own fuse boxes already setup. The bottom CB is for the fuse box in the photo. When the relay is turned on, it'll power the entire distribution block (directly above it) - this will be used for low-amp toys that only need to be on when the truck is on (things like cameras, radar detectors, etc.).
    I was hoping that a second Husky box would fit immediately behind this one (closer to the firewall), but no dice. There is a reservoir in place that gets in the way. Ordered some 1/4" lexan which I'll use to make a custom bracket/platform to hold my new BlueSea ML-ACR and the two associated circuit breakers.
    nevadabugle[OP] and TWTaco like this.
  7. Dec 23, 2016 at 3:31 PM
    #107
    nevadabugle
    nevadabugle [OP] Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    I have the switch power for all 6 coming from the break controller. You are only powering the switch itself and the tiny lights within the switch. I can't imagine that the draw is very big. I have had zero issues so far this way.
    TWTaco[QUOTED] likes this.
  8. Dec 23, 2016 at 3:32 PM
    #108
    TWTaco
    Dave
    Thanks !
  9. Dec 23, 2016 at 3:33 PM
    #109
    0210
    Vancouver, BC
    +1. Should be fine. Although I wouldn't put multiple taps on a single break controller wire. Tap it once, and run a wire from your tap to a distribution block, then run the individual switch wires from that distribution block. Less cuts/holes in the original break controller wire.
  10. Dec 23, 2016 at 3:36 PM
    #110
    TWTaco
    Dave
    [​IMG]this one correct?
  11. Dec 23, 2016 at 3:48 PM
    #111
    TWTaco
    Dave
    What did you use to cut all the holes out of the container?
  12. Dec 23, 2016 at 4:09 PM
    #112
    0210
    Vancouver, BC
    Drill a small pilot hole, then enlarge it with a larger bit, then Step drill bit. One of my favourite & most-used tools.
  13. Dec 23, 2016 at 4:13 PM
    #113
    TWTaco
    Dave
    Nice ! Are you a electrical mechanic or just one of those guys that can just do this type of work?
  14. Dec 23, 2016 at 4:32 PM
    #114
    0210
    Vancouver, BC
    Heh. No, my work is not related to this in any way. Google and YouTube are my friends, and I'm willing to share them :).
  15. Dec 23, 2016 at 4:40 PM
    #115
    TWTaco
    Dave
    So is everything inside the box secured down ( Bolted down ) nothing loose?
  16. Dec 23, 2016 at 4:48 PM
    #116
    0210
    Vancouver, BC
    It is. You can see the silver hardware going through the circuit breaker (top right), as well as all individual relays. The fuse box's cover is on, but I'm sure it's similarly attached.
  17. Dec 23, 2016 at 4:51 PM
    #117
    nevadabugle
    Elko, NV
    Yes. All secure.
  18. Dec 23, 2016 at 4:53 PM
    #118
    nevadabugle
    Elko, NV
    OR you can just run the power from one switch to the next, to the next, and so on with short wires. Look back at my photo of the sunglass holder open and you can see all the jumper wires connecting the power to each switch.
    TWTaco likes this.
  19. Dec 23, 2016 at 4:54 PM
    #119
    0210
    Vancouver, BC
    If the switches are all together, yup, even better!
  20. Dec 23, 2016 at 4:55 PM
    #120
    nevadabugle
    Elko, NV
    0210 likes this.
