Wiring an Aux Fuse Block, Relays and Switches in a 2016
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nevadabugle, Nov 15, 2015.
  1. Mar 17, 2017 at 11:23 AM
    #161
    breader3
    breader3 2016 TRD Off-Road 4x4
    Brad
    Las Vegas
    Before I got the orange straps I used a large hose clamp cut in half. Attached the same way.
  2. Apr 6, 2017 at 11:07 AM
    #162
    Khrolar
    Khrolar Well-Known Member
    Vancouver Island
    4 door 2017 trd off-road,
    None... :(
    I think it's time for a bump on this thread. Working on my setup right now, unfortunately I could not find the same husky box that all of you used. Had to settle for a clear lock container from crappy tire.:canada:
    100Amp fuse to a 100amp fuse box 4 AWG wire was used on those connections.
    5 relays stacked as well, 3 on bottom 2 on top. I'm planning on using 16ga wire to the switches and lights. The top relays wiring was removed for a better picture.
    I did really start a build thread one of these days...
    [​IMG] [​IMG] [​IMG]
    Roxanne16 likes this.
  3. Apr 6, 2017 at 1:48 PM
    #163
    breader3
    Brad
    Las Vegas
    The way those relays are stacked is genius. :rolleyes:
    I may have to redo my box when I get bored.
    nevadabugle[OP] and Roxanne16 like this.
  4. Apr 12, 2017 at 9:04 PM
    #164
    ColfaxKP
    ColfaxKP Active Member
    Kevin
    2016 DC Limited 4x4 Metallic Grey
    Love the creativeness
  5. Apr 15, 2017 at 10:31 PM
    #165
    WNYTACO
    WNYTACO Well-Known Member
    2016 Gray TRD OffRoad DC
    2 Gallon Airtank with Firestone AirRites
    Thank you to the op. I finally have started on this project. I have a ways to go but so far it looks to be pretty straight forward.
    nevadabugle[OP] likes this.
  6. Apr 16, 2017 at 8:02 AM
    #166
    nevadabugle
    nevadabugle [OP] Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    Looking good.
  7. Apr 16, 2017 at 8:03 AM
    #167
    Khrolar
    Vancouver Island
    None... :(
    Ok it took me 12 days. But I only just realised you changed the Canadian flag in my quote to an American one. You sneaky Devil.
    I used an 1 1/8" Bock to support the relays. Lifts the bottom ones just a hair and makes it easier to remove the bottom plugs.
    NathanG223 likes this.
  8. Apr 16, 2017 at 8:28 AM
    #168
    Lost In The Woods
    Lost In The Woods 4 out of the 5 voices in my head say go for it!
    Eric
    Buckley, WA
    21 Gladiator Rubicon Diesel
    An unusually high amount of pinstriping.
    lots of ideas here.:popcorn:
  9. Apr 16, 2017 at 7:48 PM
    #169
    Istan
    Istan Leave it stock they said
    Stan
    Vegas and Yuma
    03 Xtra Cab 5Speed 4*4
    I really wanted to do this but i ended up copping out and getting a pre-wired rtmr. Thanks for the inspiration, although nothing came to fruition.
  10. Apr 17, 2017 at 9:07 PM
    #170
    Metonymy
    Metonymy Well-Known Member
    2017 White Tacoma TRD PRO
    None (yet)
    Anyone want to help a newbie out? I can figure out how to combine the wiring from all the switches together so they illuminate properly, that's easy. Even the wiring of the relays seems straight forward. But what I don't understand is where to run the green wire off the switches?
    If anything in this drawing is wrong, PLEASE correct me! Also, where does the green wire go? If it's to the battery with another in-line fuse, is it possible to connect all the switches to the same single green line, run it through the firewall to a single fuse, and then to the + on the circuit breaker? I'm really trying to minimize wiring here if at all possible.
    Thank you in advance for any feedback!
  11. Apr 17, 2017 at 9:24 PM
    #171
    Khrolar
    Vancouver Island
    None... :(
    Green wire needs a + power source. It's easiest to get some jackited wire with 2 16ga wires inside it.
    Then pull that through the firewall into the cab. One wire feeds the rocker switches input and needs a + power source. The other goes to the relays input. I just used a common fuse for all of my switches.
  12. Apr 17, 2017 at 9:55 PM
    #172
    Metonymy
    None (yet)
    Got it!
    So if I'm thinking through this correctly, in-cab, you'll end up with something like this:
  13. Apr 18, 2017 at 9:07 AM
    #173
    Khrolar
    Vancouver Island
    None... :(
    That should work. Anyone one else want to way in on this? I don't want to be the one passing misinformation around, especially since I'm a Noob at this as well.
  14. May 12, 2017 at 6:51 AM
    #174
    Cold_Toad
    Cold_Toad Well-Known Member
    He has his switches powered in parallel not series.
  15. May 12, 2017 at 8:57 AM
    #175
    Cold_Toad
  16. May 12, 2017 at 9:15 AM
    #176
    Broccoli
    Broccoli Well-Known Member
    Airdrie Alberta
    2016 trd sport blazing blue,
    Heavy duty velcro, the kind that holds big fire extinguishers to brick walls.
    https://www.homedepot.ca/en/home/p.velcro-industrial-strength-4-ft-x-2-in-tape.1000112416.html
  17. May 12, 2017 at 10:16 AM
    #177
    Broccoli
    Airdrie Alberta
    If you look at his squiggly drawing, it looks like it is kinda parellel ish. But not series because the power is not going through the switch to the next one, hes pigtailing it so the line regardless will always be hot.
  18. May 12, 2017 at 10:20 AM
    #178
    Broccoli
    Airdrie Alberta
    He is daisy chaining it, which is parellel. There is no such thing as a series daisy chain.
  19. May 12, 2017 at 5:23 PM
    #179
    ICU1
    ICU1 Well-Known Member
    Thank you. It worked
    Bill Bixby[QUOTED] likes this.
  20. May 28, 2017 at 4:08 PM
    #180
    tonymac
    tonymac Well-Known Member
    Waco, TX
    2024 TRD Sport
    First post (been reading/lurking in the shadows)...I have a 2017 TRDOR. That wire harness does fit, however it is a 4 pin harness and the brake controller in the truck is 5pin (the extra wire is a purple one below green). I had to move the RED wire to the port above to connect to the green wire on the truck controller. So I am assuming there is a different harness for the 2017 or for different model/options??? See pic:
