wiring backup light
Discussion in 'Lighting' started by HerNameIsLucy, Dec 4, 2008.
  1. Dec 4, 2008 at 7:06 PM
    HerNameIsLucy
    HerNameIsLucy [OP] I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    I picked up a pair of cheap chinese made driving lights for 10 bucks on sale at Harbor Freight. Want to mount one under the truck and use it as a backing-up light.
    It's a 55 watt bulb...so it draws roughly 4 amps.
    I'd like to just hook it up to the existing lead going to one of the truck's reverse lights. Think the truck wiring would handle another 4 amp load back there, or should I run 12V to the rear and through a relay using the truck wiring to just pull in the relay?
    I know the circuit is fuse protected but I still don't wanna take chances.
  2. Dec 4, 2008 at 7:13 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    This is your best bet. :)
  3. Dec 4, 2008 at 7:14 PM
    HerNameIsLucy
    RIP Lucy.
    Thanks. I'm gonna end up building a relay box back there. I have some neon light tubes meant to go in a computer and I'm going to tuck them up under the bed side rails. May as well run a good size 12V line back there and then relay it out to where it needs to be.
  4. Dec 4, 2008 at 7:15 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    I wired mine into the existing reverse lights and have not had any problems. What is the main point/advantage to using a realy?
  5. Dec 4, 2008 at 7:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Post up some pics of the bed lights when your done! I have been wanting to do this for quite some time. :)
  6. Dec 4, 2008 at 7:17 PM
    HerNameIsLucy
    RIP Lucy.
    Will do. Going to try for a Sunday install day. Provided everything works out in the "personal" world.
    If I'm gonna relay the new backup lights I may as well put both of them under there yes?
  7. Dec 4, 2008 at 7:19 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    thanks, I guess I should go ahead and add one then
  8. Dec 4, 2008 at 7:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Oh hell yes! :D
  9. Dec 4, 2008 at 7:21 PM
    HerNameIsLucy
    RIP Lucy.
    110 watts of reverse lights not including the stock ones. My neighbor across the street is gonna LOVE me!
  10. Dec 4, 2008 at 7:38 PM
    HerNameIsLucy
    RIP Lucy.
    where did you find 100 watt bulbs that fit in that socket?
    is the lamp type in the 2nd gens the same as 1st gens?
  11. Dec 4, 2008 at 7:43 PM
    HerNameIsLucy
    RIP Lucy.
    oohhh...missed the "not the factory location" part.
    that looks good! hopefully I can find a decent mounting point for mine. peeked underneath today and don't see anywhere obvious. bottom of the bumper is wide open.
  12. Dec 4, 2008 at 7:50 PM
    HerNameIsLucy
    RIP Lucy.
    hmmm...these el-cheapo lights don't have mounts that can be rotated to the rear of them, they're kinda like off-road lamps with the mount in the bottom.
    so if i bolted a "L" bracket to the frame, then another one to that I'd end up with a "U" bracket. then i could rotate the lens on the lamps and run them upside down.
    definite possibility!
  13. Jan 22, 2009 at 3:41 PM
    08toyoamn
    08toyoamn Its For Sale. :(
    Central, OR/ Tacoma WA.
    08 AccessCab, 4.0L, 6spd
    duel polished aluminum tips, 44 flowmaster, 15% tint all round, 3" TOYTEC-spacer/AAL, TRD true cold air, tinted tails, bumper mounted B/U's, 6k HID, Painted Grill -- on the way -- black billet grill
    question... should i wire the extra lights to the reverse sensor or to an independant switch ? and im not real savy on the topic, but i have some good help at the ready...
  14. Jan 22, 2009 at 4:29 PM
    HerNameIsLucy
    RIP Lucy.
    The ones I used are 55W, so they draw a tad more power than I wanted to pull through the backup light circuit. I used a relay tripped by the backup light circuit, fed off a 12GA fused wire I ran from the battery.
  15. Jan 22, 2009 at 4:45 PM
    CAdiveTaco
    CAdiveTaco Well-Known Member
    Nor Cal
    2009 Taco DC LB Pre Runner TRD Sport
    Bed Extender, Bed matt, G4 Fold-a-cover, debadged, locked spare, taigate hoe clamp mod, TW stick
    Using a relay powered from a dedicated switch or the existing reverse light circuit and a dedicated power line to the new reverse lights will allow you to use a lower ampacity circuit to control a higher ampacity circuit...
  16. Jan 22, 2009 at 5:46 PM
    cam-shaft
    cam-shaft Well-Known Member
    Pacific Northwest
    DCTRDOFFRD
    APM system is how I wired up my back up lights and I have power for more accessories. Fully self contained accessory system, can run all kinds of accessories winch forward lights, and more. This system can even be powered up by a complete accessory battery. This system has a complete shut down system and marine grade resetable breakers and relays.
    click on slide show and show info to check out.
    http://www.flickr.com/photos/cobemotorsports/sets/72157608067149624/
    Thanks, Cam-shaft.
