Wiring Blue Sea Block to Power Only When Key is On
Discussion in '2nd Gen. Tacomas (2005-2015)' started by finsout07, Nov 20, 2016.
  1. Nov 20, 2016 at 9:04 PM
    finsout07
    finsout07 [OP] Member
    Dan
    Right Coast
    07 TRD Sport Double Cab
    Icons, Method NVs, Falken Wildpeak AT3
    So I've been reading through the Blue Sea fuse block install threads and will be installing one once my LEDs come in. I plan on adding other things later as well, however I'd like to wire it so that all of my accessories/lights that will be wired to the fuse block will only get power when the key is turned on in the ignition. Basically, I don't want the possibility of something staying on and draining power.
    I'm assuming that most of the setups shown in the install threads with the fuse block wired directly to the battery, so there's always power connected to the block.
    What is the proper way to wire a fuse block so that all of the devices attached to it only receive power when the key is in the acc or on position? Or is a fuse block the wrong way to approach this?
    My electrical knowledge is pretty basic and I haven't done anything with wiring on the Tacoma yet.
    Thanks for your help.
  2. Nov 20, 2016 at 9:12 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Iggy likes this.
  3. Nov 20, 2016 at 9:25 PM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Use a contactor (double pole relay) between the battery and fuse block. Wire the contactor to engage with ignition on.
  4. Nov 20, 2016 at 9:52 PM
    Iggy
    Iggy Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    You can do one of two things. What @robssol said. Get a big relay or contactor that connects power from the battery to the Bluesea when acc power is applied.
    Or what I prefer, relays at each fused outlet from the Bluesea. It's a bit more work because you need to add relays and all the wiring for them, but it's the most reliable way to do it.
    JeepinTaco, robssol and T4RFTMFW like this.
  5. Nov 20, 2016 at 10:40 PM
    robssol
    Rob
    S. Wisconsin
    This is actually the method I used. I wanted to use the lights (underhood, bed, and light bar) anytime, and are apparent if left on. The heated mirrors are on a timer switch and turn off after 10-15 min. You must have the coil power for the relays routed through the acc power.
    Iggy[QUOTED] likes this.
  6. Nov 21, 2016 at 1:45 PM
    finsout07
    Dan
    Right Coast
    Thanks for the input. If I were to go the contactor route, what size/Amp rating contactor would I need?
    I may try the contactor route first and then set it up for individual relays later on when I add more things to it.
  7. Nov 21, 2016 at 2:06 PM
    Iggy
    Northern CA
    Check out the build
    The contactor size is directly related to the amp limit of the fuse box. What size Bluesea did you get?
    robssol likes this.
  8. Nov 21, 2016 at 4:35 PM
    finsout07
    Dan
    Right Coast
    Planning to go with the 12 circuit BlueSea and a 100 Amp Bussman Breaker.
  9. Aug 6, 2020 at 9:12 AM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    So how did this work out for the OP? I have the same concerns about leaving on something that will kill the battery. I'm a 1st gen though, but isn't there a switched source large enough to handle the amperage for the Blue Sea?
    Edit: Switched source under the hood.
    verynearlypure likes this.
  10. Aug 6, 2020 at 12:20 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
