Wiring Delima
Discussion in 'Technical Chat' started by Nick54, Feb 10, 2012.
  1. Feb 10, 2012 at 8:59 PM
    Nick54
    Nick54 [OP] Well-Known Member
    Nick
    Mentor Ohio
    2010 Tacoma TRD Sport
    ARB Rear Locker & Compressor, Bakflip F1, Antennex 13" flexable antenna, WeatherTech Floor Liners, WeatherTech Side Window Visors, Tacoma Bed Mat, Demello Rock Crushers, Dynamax Ultraflow SS Muffler, TSB 4-Pak Leaf Springs, AFE Pro Dry Filter, Redline Hood Struts, Color Matched Angry Eyelids, Combo Lock Bed Compartments, Bed Mat, Pop-N-Lock, Wet Okoles, Goodyear Duratracs on ProComp 7033's, M101A2 Trailer, Grillcraft Mesh Grill, Light Racing UCA's, King OEM Performance Remote Reservoir Adjustable Front & Rear Shocks, JVC NT3HDT, Blue Sea Aux Fuse Panel, BAMF Behind Grill Light Bracket, Kragen 55W 7" HID's, CBI Front Receiver, Home Link Garage Door Opener, FlyEyez Light Unit, Bud Built Front to Back Skids...
    I have just purchased a Warn Multi Mount winch that comes with 2 gauge wiring to connect from the battery to the winch mounted in a front receiver. I also purchased a 24' 2 gauge wiring kit to run to the rear so that the winch can be operated in either location. Additionally I purchased a Blue Sea 12 curcuit fuse panel and Bussman 100 amp breaker. Can you give me some ideas on how to land the 6 cables (4) 2 gauge and 2 (4) gauge to the battery. Shoud I be looking for a 4 post battery?
  2. Feb 13, 2012 at 4:26 PM
    Nick54
    Nick
    Mentor Ohio
    BUMP - for some input
  3. Feb 13, 2012 at 4:34 PM
    Fractured
    Fractured FPS-a-holic
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    TRD wheels, TRD cat back exhaust, ScanGauge 2, Debadged, Avid sliders, UWS bed box w/automatic LED light, Led Interior/Reverse/Lic. Plate lights, Yellow Fogs, Flyzeye Light, Color matched grill, Rearview mirror relocate bracket, Power Sliding rear window, Plasti-dipped bumper/"T" emblem
  4. Feb 13, 2012 at 7:15 PM
    Nick54
    Nick
    Mentor Ohio
    Yep, actually I found that exact site, good info by the way. However the part I'm not sure of is how to connect up all these wires to two battery terminals. Did you notice all the different stuff I listed to connect? As I see it, 4 - 2 gauge wires for front and rear winch connections, 2 normal battery connection wires for starter and ground, 2 - 4 or 6 gauge for the auxiliary fuse buss. Whew - Help
  5. Feb 13, 2012 at 8:31 PM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    Are you thinking that you need to hook up 3 positive wire and 3 negative wires to your battery? The grounds can be tapped off of the truck frame at any point. No reason to connect grounds to the battery.
    Next, how many amps will your fuse panel handle on any given circuit? enough to handle the winch?
    Look at "pullpal.com/terminals" I think this is what you are seeking.
  6. Feb 13, 2012 at 9:01 PM
    Nick54
    Nick
    Mentor Ohio
    Good point about the grounds, but I have heard it's always better to go back to the battery for best and surest ground. IDK.
    The fused panel is capable of 12 circuits each carrying a max of 30 amps.
    Interesting link for battery clamps. Thanks
  7. Feb 14, 2012 at 6:45 AM
    slo13zx3
    slo13zx3 Well-Known Member
    Brian
    forest city pa
    14 trd off 6speed nav
    If u do that i would run a heavy wire from the frame to the batt
  8. Feb 14, 2012 at 7:27 AM
    wolftree
    Rick
    Ohio
    slo13zx3,
    I agree about the heavy wire from battery to chasis. Also clean and maintain all connections on a regular basis.
    Nick54,
    Consider tapping the positive feed for the rear winch off of the connection at the front winch. You could do both positive and negative rear winch feeds from there as well. Again, always keep the connections clean.
  9. Feb 14, 2012 at 11:17 AM
    Nick54
    Nick
    Mentor Ohio
    I think I see what your saying, however I guessing your under the impression I am connecting 2 winches (I think). 1 Winch move it front to rear.
  10. Feb 14, 2012 at 12:13 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    My superwinchLP8500 draws 320amps at rated load. You need larger breakers. Mine came with a gang of three, auto-reset breakers on a buss bar.
    You'll have to make your own buss for that many cables. Connecting them at the battery will be a cluster F. Run a main cable to a buss on the fender well. Just make sure you insulate and protect it well.
  11. Feb 14, 2012 at 12:15 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    I am using quick disconnect plugs, and a cutoff switch to keep it dead when not in use. That'll keep corrosion to a minimum, along with copious amounts of dielectric grease and RTV on the QD's.
  12. Feb 14, 2012 at 2:18 PM
    Nick54
    Nick
    Mentor Ohio
    I'm not connecting the winch to any of the 30 amp aux circuits, those are for other stuff like driving lights, bed lights etc. I like the idea of a sub bus for winch only, I will look into how to lay that out.
    Thanks
    The winch came with quick disconnect plug for front mount, and I purchased cable for rear mount with QDC's. The rear setup came with a solenoid to switch off power when not in use, haven't figured out how I want to do that for the front. Point well taken concerning corrosion, probably the most likely failure mode.
    Thanks
