wiring diagram for OEM 7 blade connector (tow package)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bobjackson2350, Oct 16, 2018.
  1. Oct 16, 2018 at 5:29 AM
    bobjackson2350
    bobjackson2350 [OP] New Member
    Robert
    2005 Pre-Runner Tacoma
    Rough Country 2" leveling spacers
    While hauling a trailer this past Saturday I noticed the trailer lights flickered on/off with every hill or bump. I could grab the plug and the lights came on if held in a certain position.The trailer lights worked fine for the guy who owns the trailer, just not on my truck. It is the first time in awhile I used the 7 blade. I had a 7 to 4 adapter plugged in for years, my boat uses a 4 flat connector. I want to replace the socket before this Saturday, I will be pulling the same trailer to a Band Competition. I want to go back with a Hopkins 48470 so I can have both available, will add a LED tailgate light bar if I get full time access to the flat connector. I read through some older forums and saw mention of a wiring diagram that would be helpful for landing the wires on the new terminals. Has anyone found that?
  2. Oct 16, 2018 at 7:24 AM
    Muddinfun
    Muddinfun Well-Known Member
  3. Oct 16, 2018 at 7:54 AM
    bobjackson2350
    Robert
    thanks for the info and assist!
    Muddinfun likes this.
  4. Oct 16, 2018 at 10:24 AM
    potstech
    potstech Well-Known Member
    Midlothian, Va
    2013 DCLB
    Check to make sure your Ground Connections are solid. Do not use the trailer hitch as a ground. Try connecting your trailer lights without the trailer on the hitch. That way you are checking out the wiring by itself. Good luck.
  5. Oct 16, 2018 at 11:49 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    sounds like a bad ground at the trailer harness
