Wiring Diagram needed
Discussion in '1st Gen. Builds (1995-2004)' started by gtrjms, Jul 29, 2025 at 11:16 AM.
  1. Jul 29, 2025 at 11:16 AM
    gtrjms
    gtrjms [OP] New Member
    Jim
    2004 Tacoma ext cab 4wd
    I have a 2004 Tacoma v6 4wd
    Last year it suddenly started running weird and couldn't get the rpms over a certain point
    Checked obvious- fuel pump- fuel pressure etc
    spark plugs- changed timing belt ( timing is on- verified by dealer and other mechanic)
    tried used ECM no luck
    Took it to a mechanic who was unable to diagnose then to dealer who $600 later was unable to diagnose and recommended sell for part ( 125,000 mile )
    The truck will now only turn over and not run at all- obviously Im getting frustrated
    As a last resort before I do that I was considering changing the engine wiring harness or going thru it and checking for any bad grounds or connectors
    If anyone has a wiring diagram or any advice- it would be greatly appreciated
    Thanks
    gtrms
  2. Jul 29, 2025 at 12:48 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Here are the diagrams for automatic and manual trucks for the powertrain control at least. If you need one for a different system like accessories or starting or something let me know.
  3. Jul 29, 2025 at 5:41 PM
    gtrjms
    Jim
    Thanks so much!!- I'll keep you updated!
