wiring diagram
Discussion in 'Lighting' started by johnw, Dec 1, 2011.
  1. Dec 1, 2011 at 3:52 PM
    johnw
    johnw [OP] Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    im looking for a wire diagrams so i can run my 3 hid 7" lights i would like to hook up two to one switch and one to another switch if somebody can help that would be awesome
  2. Dec 1, 2011 at 4:06 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    i'm headed out to the garage shortly to work on a roof rack for someone, but if i get back in later and no one's posted one, i'll draw one up for ya.
  3. Dec 1, 2011 at 4:07 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Not sure if this helps, but this is a diagram I made for myself to wire four to one switch.
  4. Dec 1, 2011 at 4:14 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    ^^^ that'll do just fine. mine's the same but i grounded to body, not battery, and my fuses are in an auxiliary fuse box. if you don't have one inlines are good, just make sure you put them somewhere easily accessible.
  5. Dec 1, 2011 at 4:17 PM
    PcBuilder14
    Brent
    Nor Cal
    Yeah, I ended up grounding them to the light bar bolts, I need to run them to a better ground because they're too exposed and corrode to easily. All my wires are zip tied together and all the inline fuses happen to line up right behind my fuse box out of the way of everything! ;)
  6. Dec 1, 2011 at 4:23 PM
    707tothe907
    707tothe907 Superior Member
    Jake
    Chico NorCal
    05 DCSB Off Road
    What's the red blob inbetween the switch and the battery
  7. Dec 1, 2011 at 4:24 PM
    johnw
    john
    orlando florida
    another inline fuse
  8. Dec 1, 2011 at 4:24 PM
    707tothe907
    Jake
    Chico NorCal
    05 DCSB Off Road
    And what's the white thing that connects all the hit wires from the light?
    About to wire my 7" HIDs as well.
  9. Dec 1, 2011 at 4:26 PM
    johnw
    john
    orlando florida
    white is the power source to the lights i believe
  10. Dec 1, 2011 at 4:30 PM
    707tothe907
    Jake
    Chico NorCal
    05 DCSB Off Road
    Yeah but do you need a special connector to put all the wires together or can you just twist them all up together?
  11. Dec 1, 2011 at 4:33 PM
    johnw
    john
    orlando florida
    um im not sure i know if you want to get a larger gauge of wire and then connect all 3 lights to that it should work. but im not so good on wiring
  12. Dec 1, 2011 at 4:35 PM
    707tothe907
    Jake
    Chico NorCal
    05 DCSB Off Road
    Okay, thanks for the help John.
  13. Dec 1, 2011 at 4:35 PM
    PcBuilder14
    Brent
    Nor Cal
    Red blob is a low power type of fuse holder with one of those small cylinder shaped fuses (Don't need a powerful fuse for a switch).
    The white wire is is what sends power from the relay to the lights.
    And I just spliced all four power wires for the lights together into one larger power wire so I wouldn't have to run 4 separate wires under my hood.
  14. Dec 1, 2011 at 4:39 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    soldering works great for that kind of stuff where it can be harder to track down the appropriate connector/reducer.
  15. Dec 1, 2011 at 4:45 PM
    johnw
    john
    orlando florida
    your welcome jake
  16. Dec 1, 2011 at 5:20 PM
    Toyota Tech31
    Toyota Tech31 Sometimes when I close my eyes, I can't see.
    Debary, Florida
    '08 SWB Bad ass SPORT
    Air Raid air intake, 40 Series Flowmaster Muffler, Front Turn Signals Now Turn And Park, KENWOOD HEAD UNIT W/ ALL KENWOOD SPEAKER UPGRADES AND 2-10" KENWOOD SUBS BEHIND BACK SEAT, Bilstein 5125'S In Rear W/ 1.5 AAL'S, Bilstein 5100 W/ Eibachs Up Front, LR Upper control arms, NFAB steps, Bruteforce Fab Hybrid front bumper, LP10000 SuperWinch, 2 Rigid Industries SRM-2's, OKLedlightbars 6 CREE LED lights as fogs, AVID RBG, 2 4" red ring HIDs mounted behind the grille.
    this is the kind of thread that i look forward to viewing here on TW, everyone that chimed in was very helpfull to one another, great job guys!
  17. Dec 1, 2011 at 5:26 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    group hug!
  18. Dec 1, 2011 at 5:28 PM
    PcBuilder14
    Brent
    Nor Cal
    Leaving because of awkward moment... :pout: haha
  19. Dec 1, 2011 at 5:30 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    damn, scared off another one. would some candy change your mind? :cool:
  20. Dec 1, 2011 at 5:30 PM
    Toyota Tech31
    Debary, Florida
    there goes colin, making things all wierd.
