Wiring diagrams or fsm?
Discussion in '1st Gen. Tacomas (1995-2004)' started by MrBiggles, Jul 10, 2018.
  1. Jul 10, 2018 at 10:38 AM
    MrBiggles
    MrBiggles [OP] Well-Known Member
    2000 Tacoma
    fj40 front axle with Detroit locker Trail gear 5" springs Rear 4 link with fox air shocks and E locker Vw 1.9 turbo diesel engine swap with a holset he211w turbo and giles performance injection pump
    Anyone have any wiring diagrams for a 2000 taco? Specifically looking for a cluster pinout and the wires involved with the vss and the 2 sensors on the tranny and tcase. Or if anyone could email or post a link for an fsm that would be sweet! Finishing up my swap and the previous owner removed the harness for the tranny as he wasnt using toyota stuff.
  2. Jul 10, 2018 at 11:23 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    I have attached the overall wiring diagram for a 2000 as well as individual ones from a 1999. You will need to verify that the 1999 is the same. It will be very similar, but some wire colors and PIN numbers do change over the years.
  3. Jul 10, 2018 at 1:09 PM
    Glamisman
    Glamisman Well-Known Member
    ^^^ I will second what he says.
    Assuming auto trans.
    I ended up having to buy the entire engine/trans harness (wrecking yard, $100) for one connector, the shift solinoid, the 3 wire one as it is no longer avalible. I traced out the wires to the ECU and sure enough, different pin locations on the ECU.
  4. Jul 10, 2018 at 1:37 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    What kind of swap are we talking about?
