Wiring ditch lights question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nirav2011, Jul 2, 2020.
  1. Jul 2, 2020 at 7:26 PM
    nirav2011
    nirav2011 [OP] Well-Known Member
    2011 Tacoma TRD Sport
    Hi all,
    I recently installed a set of CaliRaised ditch lights. Ordered the full kit (Brackets/Pods/Harness/Switch) and installation was relatively smooth.
    What I am wondering about is can the ditch lights be wired such that they only have power when the headlights are also turned on? I believe the fog lights can only be turned on if the headlights are already on (correct me if I’m wrong). I’ve tried to search here and via google but haven’t been able to find a discussion with regards to having the juice to the ditch lights being only on when juice is on for the headlights. It’s a 2011 TRD Sport.
    Also, do your headlights stay on even after you’ve shut off the engine? Does Toyota have a timer such that if you forget to switch the headlights off and walk away they will automatically turn off after a period of time?
    Thanks,
    N
  2. Jul 2, 2020 at 9:53 PM
    Spizike231
    Spizike231 Pickin’ & Grinnin’
    Jesse
    Sacramento, CA
    2011 MGM DCSB TRD Sport 4x4
    I believe the headlights will stay on if you leave the stalk turned. Not entirely sure tho, I’m OCD about all that.
    As for the ditch lights, you only want to be able to turn them on when your headlights are on? Why would it be an issue to have the option when they’re off?
    20tacoma17 likes this.
  3. Jul 2, 2020 at 10:00 PM
    Shellshock
    Iowa
    I’m guessing they want it tied to something that’s only got power when the key is flipped so they don’t get left on
    theres ways to do it. I personally just put in a switch pro and set things keyed off ignition. It’s way easier
    Spizike231[QUOTED] likes this.
  4. Jul 2, 2020 at 10:04 PM
    Spizike231
    Jesse
    Sacramento, CA
    Makes sense. Good luck OP, I’m sure there’s a way!
  5. Jul 2, 2020 at 11:38 PM
    Desert Dog
    Desert Dog Well-Known Member
    Los Gatos
    2007 DCSB
    Work in progress
    Yes and No. Yes it’s not hard to do, but no, you cannot do it with the CaliRaised harness since there is a only a single power-in lug on the harness.
    To do what you want you need 2 power leads, one from the battery through the fuse to the relay. The second power lead comes from a fuse tap you can buy and plug into the headlight fuse behind the small access panel to left of the steering wheel. This will go to your on/off switch for the ditch lights so that ditch light switch will only have power when lights are on. Or you can find the accessory fuse in same fuse panel if you only want power with key set to accessories.
    You can probably modify the CaliRaised harness if you can identify which wire provides power to the light switch, cut it and splice it to a wire that then taps into the Headlight fuse. Don’t forget to tap off other side of cut wire as it still has power going to it.
    nirav2011[OP] and Tac0maSteve like this.
  6. Jul 2, 2020 at 11:51 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The headlight on my truck go OFF once the door opens.
    However, if I open the door turn the headlights ON, and then close the door, they stay ON.
  7. Jul 3, 2020 at 12:14 AM
    TnShooter
    Deogee
    STOCK
    I’m also pretty sure the Fog Lights do NOT work if the Headlights are on High, only when on Low.
    dk_crew and nirav2011[OP] like this.
  8. Jul 3, 2020 at 3:39 AM
    nirav2011
    Thank you for the info!
