Wiring DPDT Switch W/Relay Help??
Discussion in 'Technical Chat' started by bellassaiw10, Jan 24, 2013.
  1. Jan 24, 2013 at 2:47 PM
    bellassaiw10
    bellassaiw10 [OP] Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    So I just ordered the parts to do my 4x4 swap in my prerunner, the parts I got are for an ADD and it comes with the push button TC know, I got a wiring diagram off of TTORA but I'm a little confused as to exactly interpret it.
    BLUE Box: Stock Plug ?
    RED Box: DPDT Switch
    Black Box: Relay
    Basically is the 30 on the relay going to the Batt. Ground ?
    and where exactly would I wire the push button into because the diagram is confusing :confused:
    What is the middle slot on the switch on the right hand side go to ? nothing ??
    Also I dont want to wire in any of the lights that he has in the bottom of the stock switch.
    The only light I want to wire is the green 4wd dash light
    Would it be easier to just wire it like this with no relay? http://www.instructables.com/id/HOW-TO:-Wire-a-DPDT-rocker-switch-for-reversing-po/?ALLSTEPS
  2. Jan 25, 2013 at 2:04 PM
    bellassaiw10
    Currituck NC
    No one...
  3. Jan 28, 2013 at 1:39 PM
    bellassaiw10
    Currituck NC
    :confused:
    Nobody has any insight at all lol ?
  4. Jan 28, 2013 at 2:03 PM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    start with a better diagram....:confused:
  5. Jan 28, 2013 at 3:15 PM
    bellassaiw10
    Currituck NC
    Im in the process of re writing as I type
  6. Aug 31, 2013 at 5:10 PM
    Order66
    Order66 Four Wheel Drive With Room For Five!
    Nick
    Georgia
    88 4Runner SR5 V6
    3 inch body lift, 33x12.50x15 Pro Comp A/Ts, Front and Rear Tube Bumpers
    The link you provided will work for wiring any DPDT switch. Use the wiring as said in the directions. I know when wiring power windows you don't have to use a relay. You simply take any one of the middle prongs on the DPDT switch and wire and ground to it. With the other middle prong you can run a hot wire (preferably with a fuse) to a power constant. I don't know if you can do this in the situation you are in. You might want to do more research into it. Here is a diagram I have found all throughout the internet that shows wiring a DPDT switch to relays. I guess you would just swap the motor with what you are wanting to control. Hope this some insight you were looking for. :)
