Wiring Driving Light Switch...suck at auto electrical!
Discussion in 'Lighting' started by icegrill, Dec 17, 2017.
  1. Dec 17, 2017 at 7:58 PM
    icegrill
    icegrill [OP] Well-Known Member
    Oregon
    2015 Tacoma TRD (sold) bmw F80 M3 current
    I just wanted to get some input on if I have this hypothetically wired correctly and I'm not going to tap into another wire for the headlight on illumination.
    Thank you so much!
  2. Dec 18, 2017 at 7:34 PM
    icegrill
    Oregon
    anyone?
  3. Dec 19, 2017 at 8:16 PM
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    Looks good to me, if you do want it to light up you could also just use an add a fuse and tap into a fuse that's powered when the headlights turn on.
  4. Dec 19, 2017 at 8:27 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Disregard the switch side of the KC diagram entirely.
    On relay side: Black to ground, yellow to battery, green to toyota switch green.
    On toyota switch: Black to ground, yellow to dash light circuit, green to KC relay green, blue to add a fuse plugged into high beam fuse location (for use with high beams only, for use with high/low or parking plug into tail light fuse location).
    EDDO likes this.
  5. Dec 19, 2017 at 9:36 PM
    icegrill
    Oregon
    Thank you it worked perfect! I used the acc. Fuse #5 so they will work anytime the ignition is on.
  6. Dec 19, 2017 at 9:44 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    Glad it worked out for you. Peronally, I have my lights controlled by my high beam circuit. That way i can deactivate them quickly (I use my lights on the road in areas of animals/rocks and little traffic) and its easier to just flip the highs off.
  7. Dec 28, 2017 at 2:20 AM
    Capt Tacoma
    Capt Tacoma Well-Known Member
    2017 TRD Sport DCSB
    So I am very new to this. I just installed my light bar, it is always hot and the switch light is always on. How did you hook it up to run with your high beams?
  8. Dec 28, 2017 at 8:01 AM
    windsor
    windsor Just a guy
    Homeless in Oregon
    Use the high beam circuit to run the control side of the relay. I think people have said 3rd gen are ground controlled circuits, so probably have to check that.
    For 2nd gen, use add-a-fuse to tap the high beam circuit in the engine bay fuse box and run that to the pos of the control side (86) of the relay. Then you can run the ground side (85) of the relay directly to ground (light always comes on with high beams), or run it to an aftermarket switch in the dash (you can choose if lights come on with high beams or not).
    From personal experience, always use a weatherproof relay.
