Wiring dual fuse block.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by LTG4087, Oct 8, 2019.
  1. Oct 10, 2019 at 10:19 AM
    caribe makaira
    Caribbean, Puerto Rico
    Any circuit above 10A to relay...higher amps closer to battery feed, lower amps away from battery feed wire. Relays (85's) to cab switch to ground. In this example you have 4 relays ON anytime and 6 relays only available after IGN. (10a INJ fuse) Two (2) spots for miscellaneous (HF radio?):anonymous:
  2. Oct 10, 2019 at 3:08 PM
    SSG (03)TACOMA
    SSG (03)TACOMA SSG TACOMA
    2023 DOUBLE CAB V6 TRD SPORT 4x4
    IMG_20191010_120105765_HDR.jpg this is my set-up
  3. Sep 5, 2024 at 7:14 AM
    pineapple_taco
    pineapple_taco Member
    James
    21 Taco TRD Sport
    400 watt inside cab AC
    Two questions for you:
    What sub panel / relay mount is that? I was about to fab my own.
    And how on earth do you keep your engine bay so sparkly clean! Looks amazing.
