Wiring expert help with led sider markers
Discussion in 'Lighting' started by knine00, Jun 17, 2012.
  1. Jun 17, 2012 at 3:03 PM
    knine00
    knine00 [OP] Well-Known Member
    Hudsonville, Mi
    12 PreRunner DC TRD Sport
    Stock for now
    I am trying to install three 3/4" led side markers. I want to wire them to a switch and not the turning signals. Will this require a relay?
    I am installing these:
  2. Jun 17, 2012 at 3:04 PM
    Forster46
    Forster46 Very nice how much?
    Nick
    Mount Vernon, WA
    The doritos locos taco
    6000k HID's, AUX Reverse Lights, 3" Rough Country Suspension Lift, Pioneer AVH-P4200 Double Din, Underglow and footwell Lights, Camo Seat Covers, Duralast Tool Box, Blacked Out Badges, Grill, Front Emblem, Midland CB Radio, Amber Strobes, POWER REAR WINDOW, cup holder LED's, Firestik 3' in bed, console divider, Ultragauge.
  3. Jun 17, 2012 at 3:05 PM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    What is the amp draw? If switch is rated enough should be fine... what are you going to use them for?
    I use relays for everything... lol
  4. Jun 17, 2012 at 3:08 PM
    knine00
    Hudsonville, Mi
    Stock for now
    Kinda like the raptor setup! I have Contura v switches
  5. Jun 17, 2012 at 3:14 PM
    Forster46
    Nick
    Mount Vernon, WA
    So only two red lights in the front? Or did you buy two sets?
  6. Jun 17, 2012 at 3:17 PM
    knine00
    Hudsonville, Mi
    Stock for now
    No, I am doing three white ones. I bought them from led warehouse.
  7. Jun 17, 2012 at 3:24 PM
    nfs257
    DFW
    She gone
    3 leds should be fine in one switch. If you want to protect the dwight use a relay. Not much more work at all.
  8. Jun 17, 2012 at 3:31 PM
    Forster46
    Nick
    Mount Vernon, WA
    Ohh okay. Cool
  9. Jun 17, 2012 at 3:31 PM
    knine00
    Hudsonville, Mi
    Stock for now
    Where is a good place to get a relay online? Is there a certain type?
  10. Jun 17, 2012 at 3:41 PM
    nfs257
    DFW
    She gone
    Radio shack or oznium.com
    A 4 pole will work most are 5 pole and you use only 4 poles...
  11. Jun 17, 2012 at 3:43 PM
    knine00
    Hudsonville, Mi
    Stock for now
    Do you know where I can get a wiring diagram?
    thanks for all of your help
  12. Jun 17, 2012 at 3:48 PM
    nfs257
    DFW
    She gone
  13. Jun 17, 2012 at 3:48 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Not really a "4-pole".... the contacts only have one pole.
    You have a N/O (87), common (30), and some have a N/C (87a)
    The relays are 4 or 5 PIN. Pins 85 and 86 are the coil terminals that switch the relay.
  14. Jun 17, 2012 at 3:50 PM
    nfs257
    DFW
    She gone
    You are correct... sorry for the confusion.
  15. Jun 17, 2012 at 4:04 PM
    knine00
    Hudsonville, Mi
    Stock for now
    So I can use a 4 pin? That would mean its a N/O relay correct? 5 pin just gives you a choice between n/o or a n/c relay?
  16. Jun 17, 2012 at 4:13 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Correct.
    Pin 87 is usually used as the output.
    Personally, I prefer to reverse 87 and 30 for safety reasons IF I'm using a 5-pin. Why? 87a is the NC contact. When the relay is not energized (switch off, truck off), 87a is hot... direct connection to the battery.
    This doesn't matter on the 4-pin, and really, it's not a big deal on the 5-pin as long as you put some shrink tubing over 87a.
    There are some good uses for the 5-pin relay, example, you can use the 87a output to feed a 2nd relay to automatically switch between fogs and driving lights when you switch from low to high beam.
  17. Jun 17, 2012 at 4:17 PM
    knine00
    Hudsonville, Mi
    Stock for now
    I gotcha. So a 5 pin can be used with a on/off/on 3 position switch?
  18. Jun 17, 2012 at 4:22 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    That's actually a 2-position switch with an indicator light.
    The ground connection is the ground for the indicator.
    Switch pulls in the relay that connects the battery to the rest of the system.
    The switch gets it's power from the parking lights, so when the headlights are off, the whole system goes dark.
    Power normally flows from the 1st relay 87 to the 2nd relay pin 30, and out pin 87a to the fog lights.
    When the high beams are turned on, the hot from the high beams closes relay #2, which redirects the output of relay #1 to pin 87, to the driving lights.
  19. Jun 17, 2012 at 4:25 PM
    knine00
    Hudsonville, Mi
    Stock for now
    Awesome thanks for the info!
  20. Jun 17, 2012 at 4:53 PM
    nfs257
    DFW
    She gone
    That confused me... lol
    I need to read and study that again...
