Wiring extra reverse lights to switch and preexisting lights
Discussion in 'Lighting' started by CliffordBRD, Mar 1, 2013.
  1. Mar 7, 2013 at 7:28 PM
    Ryan DCFS
    Ryan DCFS Elevator guy
    East Bay Area
    09 DC long bed TRD silver streak
    Here is a diagram I put together yesterday, it's how I wired my AUX lights, and requires no diode.
    I used an SPDT 3 position toggle switch, instead of an SPST switch (type that comes with most aux lights). The switch I have is on (with reverse) -off-on (anytime/acc), with one incoming power from the reverse lights circuit, and one incoming power from a fuse tap on an acc circuit, the outgoing (common pin) on the switch goes to the 86 pin on the relay.
    This eliminates the need for a diode, because the two sources (rev/acc), are never connected, as they would be if you connect both sources to the 86 pin directly.
    hoverlover and Grantu1w like this.
  2. Mar 7, 2013 at 7:53 PM
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    I recommend a 5 amp diode.
    If you wish to use a 3 position switch (which is actually pretty nice) then this is perfect. I wanted mine OEM as possible so I used an additional OEM fog light fuse for my switch so i coulnt do it this way. But nice diagram, if OP can understand it :eek:
  3. Mar 8, 2013 at 10:10 AM
    CliffordBRD
    CliffordBRD [OP] Well-Known Member
    Cliff
    Tampa, FL
    09 DCLB 4x4 Pyrite Mica
    ya...about that diagram...going to need that broken down into laymen's terms.
    I'm going to get this switch from www.otrattw.com which is the following:
    V6D2UHNB – SPDT ON/OFF/ON –
    Green upper LED
    Amber lower LED
    Both LEDs are independently wired and have separate ground terminals.
    This switch could be installed upside down to place the amber LED at top, green LED at the bottom
    Seven terminal switch with no rear barriers between the terminals
    Use insulated ¼” female disconnects or the VC1-01 connector housing (Packard terminals for the rear housing are sold separately)
    Verify that a SPDT switch is suitable for your application prior to purchasing this switch. If a DPDT switch is required use the VJD2UHTB or similar VJD model switch.
    Once ordered I think I'll be ready to go since I won't need a diode being I'll be using the 3 position switch. I know this isn't rocket science, but just the basics to doing something right the first time...
  4. Mar 8, 2013 at 11:06 AM
    Ryan DCFS
    East Bay Area
    How are you going to try to wire the light elements of the switch?
    The carling switches are kinda interesting as far as wiring the [switch's] lights goes. You definitely went the right direction getting the independently wired lights, though, because the dependent ones would be jumped in a way that you probably wouldn't want, since you're going to be reversing the in/out pins of the switch. The part number you gave denotes a 10 terminal base, but maybe otrattw got rid of 3 of the pins (4,5,6 pins would be used for a dpdt switch, 1,2,3 are for spdt) somehow to make it simple.
  5. Mar 8, 2013 at 11:18 AM
    CliffordBRD
    Cliff
    Tampa, FL
    Honestly, I have no idea. I am assuming there is 3 pins on the back of the switch, two for power and one for a ground...but they don't have pics of the back of there switches. Guide me in the right direction because I'm supposed to be moving forward but I think I'm moving backwards...
  6. Apr 9, 2013 at 3:50 PM
    CliffordBRD
    Cliff
    Tampa, FL
    Bump for some help with this. Can't seem to find a diode at any local stores.
    I've got everything else ready to go.
    How do I go about using the 3 position switch with lighting it? I really like the otrattw switches, but didn't know they are more complicated than others.
    I am correct getting the SPDT switch, right? Help me, and I'm sure others, complete this simple mod....
  7. Apr 9, 2013 at 4:41 PM
    rockgecko03
    rockgecko03 Well-Known Member
    Ben
    Rockwall, TX
    1999 Tacoma - Perpetual Project
    You can find the diodes at radio shack. They come in a pack of 3 the last time I bought them (year or two ago).
    EDIT: Did your switch come with a wiring diagram? If so, that would be the best resource or hooking it up. If not, I would check out OTRATTW's website.
  8. Apr 9, 2013 at 4:52 PM
    CliffordBRD
    Cliff
    Tampa, FL
    Ah OK. I didn't want to order it yet without knowing its the exact one I looking for. I'll order the spdt switch which will have on always/off/on with reverse...right?
  9. Apr 9, 2013 at 9:14 PM
    Ryan DCFS
    East Bay Area
    With the spdt switch and the wiring diagram I posted, you will not need a diode.
  10. Apr 9, 2013 at 9:50 PM
    joes06tacoma
    Joe
    Central Coast, CA
    X2
    I've done this on three trucks now, never used a diode. SPDT switch and a separate pilot light. Would be better to have a fancy rocker switch like some of these guys, but I'm too lazy to sort out which one to order.
    In any case, no diode necessary.
  11. Apr 11, 2013 at 10:38 AM
    CliffordBRD
    Cliff
    Tampa, FL
    Can someone break down the symbols used in this diagram? I tried to find them online but I don't understand all of them and how they all connect like then diagrs displayed on the first page. Sorry for being such a noon. I really appreciate all the help!
  12. Apr 11, 2013 at 2:15 PM
    ProForce
    Anthony
    Alaska
    They are basically already labeled, but I'll draw you a simple diagram in a few minutes.
  13. Apr 11, 2013 at 3:38 PM
    ProForce
    Anthony
    Alaska
    This is the easy to understand drawing... (Hopefully)
    And this is the answers to your symbols
    hoverlover likes this.
  14. Apr 11, 2013 at 4:14 PM
    CliffordBRD
    Cliff
    Tampa, FL
    Gotcha! Time to get it all done! I really appreciate the help!
  15. Jan 10, 2014 at 2:11 PM
    #35
    HighTideTaco
    HighTideTaco The Way Life Should Be
    Jon
    Maine
    2010 TRD Sport
    Swapped Hoods (!!!), DTRL Toggle Switch, Disabled seatbelt/ignition chime, Disabled lock/unlock beeps, Installed D-Rings in bed, Debadged "Toyota" on transom (now just one line straight across), Removed mud flaps, Removed TRD Stickers, Custom aluminum "ladder rack" with CB mount (Wilson 2000 Trucker; Uniden 520), WeatherTech; Just getting started!
  16. Jan 10, 2014 at 5:48 PM
    #36
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    Ok someone draw me a diagram for my front top front 30" light bar to come on with high beams or a switch. I have a feeling I got it right by connected the switch pin on the relay to high beam wire and back to the switch... issue is when I flip my switch in the truck (otrattw) the high beams comes on. Do I need to wire in a diode? And if so where
  17. Jan 11, 2014 at 12:40 PM
    #37
    yellowrubiu
    yellowrubiu Well-Known Member
    Empire State
    2012 DCSB 4x4 SR5
    Guys, this is great information. Thank you!
    I am doing the same modification to add auxiliary backup lights and will be using the diagram posted above as a reference. However I need a little help.
    Can someone please let me know the fuse amperage to be used for the 3 positions numbered in red on the diagram. I am using a set of Rigid Industries Dually LED lights. They are 20 Watts with an AMP draw of 1.45 according to the specifications on the box... I'm assuming this is per light. Would 1 & 2 be 10 AMP and 3 5?
    Also can someone confirm the relay pin labeling is correct. One of the diagrams above shows pin 30 going to the auxiliary lights and 87 to the battery source. Another comment in a different post describes the reverse setup. I'm guessing both setups will work since the net result is the same when the current passes through the connection between pin 30 and 87.
    Lastly I would like to tap into the reverse light circuit somewhere in the kick panel or door sill in the cab but can't seem to find anything detailing which cable this would be on a 2012. If anyone knows that would be very helpful also.
  18. Jan 18, 2014 at 5:34 PM
    #38
    Beaker76
    Beaker76 Well-Known Member
    Nick
    Garner, NC
    13 TRDOR DCSB
    ICON Stage 1, 255/85/16 ST Maxx, SOS Concepts WIY Front Bumper
    Sub'd for great information
  19. Jan 18, 2014 at 5:53 PM
    #39
    Ryan DCFS
    East Bay Area
    Fuses 2 and 3 would be the same amperage (2.5-5) but those circuits will never draw anything close to that. They are fuse taps that control the coil side of the relay circuit, which will only draw about 0.1 amps.
    Fuse 1 (going to the 30 pin) is going to be rated for
    The amp draw of the accessory (the lights, in your case).
    The placement in the diagram I made, with 30 being the hot side, is correct, however reversing the 87 and 30 would have the same net result and wouldn't be detrimental (unless you had a 5 pin relay with an 87a and are using both pins). The 30 pin is generally the pin for the incoming power, and the 87 is the NO output.
    When I wired mine, I spliced it into my "backup camera anytime" mod wiring. If you search for that mod on here, there is a location for a reverse circuit in there somewhere.
  20. Jan 30, 2014 at 6:41 AM
    #40
    chri
    chri Active Member
    Arkansauce
    Too Stock
    OME 887, Dakar HD, Icon delta joint UCA, method roosts, BFG KO2s at 285/70/17 Alu Cab canopy
    Helpful, I'm holding onto this for future backup lights. Thanks!
