Wiring extra reverse lights to switch and preexisting lights
Discussion in 'Lighting' started by CliffordBRD, Mar 1, 2013.
  1. Feb 6, 2014 at 4:53 AM
    #41
    Tatanka
    Tatanka Well-Known Member
    Pennsylvania
    2014 DCLB TRD
    I will use this. Nice work.
  2. Feb 6, 2014 at 5:06 AM
    #42
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
  3. Feb 11, 2014 at 10:51 PM
    #43
    Chepo
    Chepo Tankoma!
    Chepo
    Mexico City
    '11 TRD Sport
    Lots...
    Wow! this is a great thread!!! I was looking for something like this cause Im gettin a new rear bumper and will include extra reverse lights!
    Thanks!!!!
  4. Feb 23, 2014 at 5:12 AM
    #44
    MTopp
    MTopp Professional bear handler
    05 SR5 4x4
    trifecta tonneau, pop n' lock, Depo black bezel headlights, mb 352 wheels, 265/75r16 cooper at3s, visors, colormatched 2011 grille with raptor LEDs, much LEDs in and out Future/wanted: black valence, hood scoop, catback, CAI, 285/75r16s, OMD leaf pack mod
    Is this true for all lights/LEDs? I just installed some LEDs in the interior and spliced all the positive and ground together
  5. Feb 23, 2014 at 11:26 AM
    #45
    Ryan DCFS
    Ryan DCFS Elevator guy
    East Bay Area
    09 DC long bed TRD silver streak
    All positives together and all grounds to ground is fine. You just don't want positive to negative to positive to negative. That's series and you want parallel, which is what he's describing.
  6. Feb 23, 2014 at 12:59 PM
    #46
    MTopp
    05 SR5 4x4
    Ohh, alright, yeah, then j understand you'd lose voltage
  7. Feb 23, 2014 at 8:17 PM
    #47
    Denk
    Denk Well-Known Member
    PNW
    '13 Spruce TRD Sport DCSB
    Great info here. Have been trying to work out this setup for a while now. I like the idea of using the DPST switch but would much rather stick with SPST.
    - switch off, aux lights auto on with reverse
    - switch on, aux lights manual override on
    Can someone please confirm...
    30 - fused 12V from battery (aux block)
    85 - ground
    86 - 12V load from switch (w/ diode)
    - 12V load from reverse circuit (w/ diode)
    87 - 12V supply to aux lights
  8. Feb 24, 2014 at 4:29 AM
    #48
    MTopp
    05 SR5 4x4
    Look at post 34, I couldn't quote it from my phone for some reason
  9. Feb 24, 2014 at 5:31 PM
    #49
    Denk
    PNW
    now that i reread the thread, i think the diagram from post 22 is what i need.
  10. May 30, 2014 at 7:32 PM
    #50
    Databox
    Databox Well-Known Member
    Fernandina Beach, FL
    2007 TRD Sport SR5
    Rims and Tires
  11. May 30, 2014 at 7:52 PM
    #51
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    There is an alternative that was overlooked. Since the LED lights have a relatively low current draw, they could be switched on and off with just a SPST toggle switch without needing a relay to control them. Add this in parallel with a relay that would be controlled by the reverse light circuit and now you have the new reverse light circuit and the original reverse light circuit electrically isolated from each other while being able to control the new lights with either the reverse circuit or with a switch.
    I don't have this drawn out here but it is fairly simple.
    The important thing to remember is the switch has to be rated high enough to switch whatever amperage the new lights draw. If the draw is low enough, you shouldn't need the switch to control a relay. You can power the lights directly from the switch.
  12. Aug 26, 2014 at 6:14 PM
    #52
    1993t100
    1993t100 I’m good looking and I drive a Jeep.
    Big Sexy
    Nebraska
    Jeep Wrangler Rubicon
    Sorry for reviving an old thread, but I have some questions.
    I'm looking to run LED lights, so not a ton of power. Can I run a 12v right from the battery to a relay, and tap into the positive wire that goes to the positive on the tail light, and run that to the relay, then ground the relay? I don't know which pole to go on each but I don't care to turn the lights on with a switch too, I just want them to come on when I shift into reverse.
  13. Sep 22, 2014 at 11:27 PM
    #53
    Pode
    Pode New Member
    NotMyTaco - Yet
    Los Gatos, CA
    2014 DCSB 4x4 SR5 in Black
    1000w Inverter, Fogs Anytime, LED Strip Bed Light, 110v power in Console, 12v High Amp winch power front and rear
    Sub'd
  14. Oct 14, 2015 at 11:19 AM
    #54
    KingofSea
    KingofSea Active Member
    Tampa, Fl
    2015 PreRunner Sport V6
    Clazzio seat covers, Front Seat Heaters, Matt Gecko Bed lights, WeatherTech Floor Mats, Go Rhino Step Bars, Redline Hood Struts, Black Texas Edition Wheels
    I purchased and 3 position switch Always On- Off -Manual On . Does anyone know why my LED on the switch would alway be illuminated in the off position?
  15. Oct 14, 2015 at 1:39 PM
    #55
    Glueman
    Glueman Yersinia pestis
    Utah
    The Plague....
    6 inch Douche Bag lift...what else do I need?
    You likely have power running to it that lights the internal switch LED. Do you not want to see the switch in the dark???
  16. Oct 14, 2015 at 1:49 PM
    #56
    KingofSea
    Tampa, Fl
    will it drain my battery this way? I just thought that was the point of the 3 positions? 1 For automatic lights when it gets thrown into reverse with the LED illuminate, 2 the Off position nothing illuminated 3 Manual on when you need lights without putting into reverse LED illuminated.
  17. Oct 14, 2015 at 1:51 PM
    #57
    Glueman
    Utah
    The Plague....
    If the switch light is always on, yes. You should run the wire to a circuit that runs off the headlights so it only illuminates when the lights are on.
  18. Oct 14, 2015 at 1:58 PM
    #58
    KingofSea
    Tampa, Fl
    I guess i am missing something. Here is the wiring diagram the vendor gave me? I guess my questions is could i have tapped something other than the brake light? I tapped into the Red 12 V wire in the rear where the reverse bulb is located. Could that be supply constant current? Any help would be greatly appreciated.
  19. Oct 15, 2015 at 10:25 PM
    #59
    Chepo
    Chepo Tankoma!
    Chepo
    Mexico City
    '11 TRD Sport
    Lots...
    Well, I do believe the diagram is wrong...
    87 and 87a in the relay are outputs (to the lights or accesories you want to power)... 86 must be input power from the switch, 30 is the fused input from the battery...
    I don't know how is the interior of the switch, but if you don't want the light to turn on at allo, you just disconnect #7 of the switch
  20. Oct 16, 2015 at 7:20 AM
    #60
    KingofSea
    Tampa, Fl
    here is a picture of the relay
    Pin 1 to Power connected to switched relay at 87
    Pin 2 connected to switched relay at 86
    Pin 3 connected to reverse light
    pin 7 grounded to truck
    not sure if that help. Just seems weird that the lights turn on and off when supposed to, but the bottom LED is alway illuminated in any position the switch is in.
