Wiring extra reverse lights to switch and preexisting lights
Discussion in 'Lighting' started by CliffordBRD, Mar 1, 2013.
  1. Dec 29, 2015 at 12:46 PM
    #61
    captainchris
    captainchris Member
    chris
    Georgia
    11 Prerunner SR5
    is there a harness already set up like that
  2. Jul 17, 2016 at 10:52 AM
    #62
    Grantu1w
    Grantu1w New Member
    Ryan DCFS, how many pins does the 3 position toggle switch need to have for that set up?
  3. Aug 9, 2016 at 7:20 PM
    #63
    Ryan DCFS
    Ryan DCFS Elevator guy
    East Bay Area
    09 DC long bed TRD silver streak
    Three minimum... But it could be more depending on the nature of the switch. The number of pins is irrelevant if the action of the switch isn't correct (spdt, dpdt would work) the important part is that it's double throw.
  4. Sep 19, 2016 at 5:31 PM
    #64
    stevespens
    stevespens Tacoma Addict
    Fort Mohave, Arizona
    06 Pre-Runner Quad Cab Rad Red
    2014 nose conversion in Radiant Red, Raceline Raptor wheels w/ 265/75R16's, Go Rhino chrome nerf bars, Pioneer AVH-X3600BHS stereo, leveling kit 2 1/2" and 1", tinted windows, color matched grill, Dynomax Syst-Ultra flow cat-back,
    Hey folks. Will this switch work for an "always on-always off-on with reverse lights"?
  5. Sep 20, 2016 at 3:31 PM
    #65
    stevespens
    Thanks anyway, already done. Worked like a charm.
  6. Sep 30, 2018 at 8:02 PM
    #66
    radriguezzz
    radriguezzz New Member
    Denver Colorado
    2012 Red Tacoma Prerunner
    Just finished mine! Thanks for the write up.
    B48DB497-184A-4F95-BA05-9A4CEA02B403.jpg 497E6AF8-C81D-4411-B6A6-A9F16D21BCFB.jpg
    Wired up some interior camper lights while I was in the mood to do some electrical work.
    5CF364D8-1671-475C-BD6F-170F12676357.jpg 2A4C71E9-C620-4611-A978-6AD5D6071AEF.jpg
  7. Feb 12, 2020 at 12:05 PM
    #67
    pavement.is.lava
    pavement.is.lava Well-Known Member
    SLC, UT
    2015 DCSB TRD OR 6MT
    285/75r16 KO2s, Dobinsons 3” lift, BAMF bumper/sliders, skids, Allpro Rack
    What do you guys think of this? My goal is to be able to use my aux reverse lights as camp lights (switch mounted in the bed for easy on and off when cooking on the tailgate), and to have them come on with the reverse lights (but be able to switch this off from the cab for when I'm doing city driving).
  8. Feb 12, 2020 at 12:47 PM
    #68
    pavement.is.lava
    SLC, UT
    This is the other option I came up with. It would allow me to turn on the lights from the bed even if I left the switch in the cab off. Would this work as well?IMG_9647.jpg
  9. May 13, 2020 at 5:21 PM
    #69
    PNW Explorer
    PNW Explorer Well-Known Member
    Idaho
    2018 Tacoma TRD OR DCLB Mag Gray
    Not sure which post you are replying too, but a lot of posts wanted the ability to trigger via reverse as well as via a switch. That way they can use them for camping as well as automatically for reverse. So just splicing into the reverse lights doesn't work in that case. As well as the fact that depending on the amperage draw it isn't the best solution because the wire/fuse might not be rated if the new lights are powerful.
    I had my baja design lights (in my aftermarket rear bumper) automatically trigger with reverse and had about 5 people stop me in broad daylight (over the course of an hour or two) saying my lights were way too bright. Now they are full time switch controlled.
    BizzyB726 likes this.
  10. May 13, 2020 at 6:03 PM
    #70
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    You could use a DPDT On/Off/On switch to do that. Up for on, neutral for off, down for on with reverse wired to the back up lights.
    Bravisimo likes this.
  11. May 13, 2020 at 6:12 PM
    #71
    PNW Explorer
    Idaho
    Thought about that route but went the Spod route instead. Click of a button on the app or asa and I can turn groups of lights on at once. Pair that with assigning lights to multiplegmultiple (camp, drive, etc) and it solved all my problems and then some.
  12. May 13, 2020 at 6:17 PM
    #72
    hoarder23
    Shay
    NJ
    Scratches
    Yeah, I went the SwitchPro route. One of the few gripes is that on/off/on is not supported.
  13. May 13, 2020 at 6:38 PM
    #73
    PNW Explorer
    Idaho
    Does the switch pro not have an additional input terminal block? I use the extra inputs along with the app and Spod switch panel. I can tie a thermostat or other sensors to the input terminal to activate circuits. I.e. you could splice in the reverse signal to activate the circuit.
  14. May 15, 2020 at 12:26 PM
    #74
    Tonyrav
    Tonyrav New Member
    Tony
    Rav4
    Hey man, hope you all are safe and well . New to the forum and have been trying to follow your post in trying to wire my backup camera with a switch following your diagram but no dice. I have it working with a normal switch however my reverse lights keep coming on and making the vehicles computer think I’m in reverse giving me a check engine light. I tried using a diode between with the reverse lights and switch on two legs and the reverse trigger wire on the banded end but still no go. No extra lights or anything just a simple switch to override and not have to go in reverse.
    thank you for all of the useful information you’ve posted thus far
  15. Jun 8, 2020 at 9:16 PM
    #75
    BizzyB726
    BizzyB726 Well-Known Member
    Brandon
    New Jersey
    2012 Black Tx Baja
    I don't mean to hijack the thread but i'm doing an identical install this weekend. Got a pair of Rigid Midnight diffused flush mounts in the bumper and i'm looking to do a spdt switch.
    I have the dual lead harness that came with them that I want to utilize but to my surprise, it came unprotected and without a relay. So I ordered a new dual lead harness off Amazon with a relay but now i'm realizing I need extra wires to do this install with on-off-on functions.
    How exactly should I go about this install now?
    Since the harness is only power and ground for each light, I assume I should grab some extra wire to attach to relay, switch etc.?
    So my plan..
    Run the harness as normal from battery to rear bumper but I'd like to tap into the reverse wire that is in the bottom left foot well of drivers side. I believe Terminal 1, red wire with a white stripe in connector ID2 as stated in the "How do I find my Reverse Signal Wire" Thread.
    Can I just tap into this wire with a T tap and follow the above diagrams as in post #77?
  16. Jun 8, 2020 at 9:29 PM
    #76
    BizzyB726
    Brandon
    New Jersey
    2012 Black Tx Baja
    I'm looking to find the same.
    I've been on the OTR site as well as others trying to find one. I believe I've seen one while reading through random threads but I can't find it.
