Wiring for extra reverse light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 4r_to_taco, Oct 1, 2017.
  1. Oct 1, 2017 at 4:32 PM
    4r_to_taco
    4r_to_taco [OP] Well-Known Member
    florida, east coast
    2006 double cab trd off road
    rear diff breather extension, slotted/cross drilled brakes
    How did you connect/tap into tail light wiring? Or did you leave it as a dash switch?
    I know there is a crimp that goes on wire ends and then clips over wire to cut into and make a connection. Just looking for options..
    Reverse lights don't do a good job with the topper I have and I don't think just replacing factory tail lights with led's will make enough of a difference for me.
  2. Oct 1, 2017 at 4:56 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    There's a write up on here that replaces the bulbs with GY6.35 bulbs. You'll have to squeeze the connectors a bit in the socket but the lights fit. I was using 50W without any issues but some had reported some socket damage and the consensus is to run 35W bulbs. Plenty of light with that mod.
  3. Oct 1, 2017 at 5:19 PM
    gearcruncher
    Canadain bumper technician
  4. Oct 1, 2017 at 5:20 PM
    Muddinfun
    Muddinfun Well-Known Member
    I put in the Deauto LED reverse light bulbs and put 120 LED switchback LED bulbs in the turn signals. When I drop it in reverse, it's like having 4 headlights on the back of the truck. It lights up everything behind the truck and straight out to the sides. Some people think the Deauto LEDs are too expensive. Every time I drop it in reverse and people have to look away, it's worth every dollar. The added bonus is that with 60 amber LEDs per side, there is no doubt to people behind you that you are turning. Plainly obvious from several blocks away.
    https://www.tacomaworld.com/threads/switchback-leds-in-rear-turn-signals.507529/
    https://www.tacomaworld.com/threads/the-921-led-reverse-light-bulb-study.490137/
  5. Oct 1, 2017 at 5:22 PM
    gearcruncher
    I was going to mention adding a couple more leds would really be bright . You beat me to it . Nice thing about LED,s ....They dont use much power and sure brighten things up
  6. Oct 1, 2017 at 6:57 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    vssman likes this.
  7. Oct 2, 2017 at 10:28 AM
    4r_to_taco
    florida, east coast
    Thanks to all who replied.
    Went in search of a slim led light bar from local stores and came up empty. Ended up getting some led replacements for factory reverse lights.
    Still going to find the right slim led bar to use as extra light if needed and for a work light when loading/unloading boat in dark. Got an idea up my sleeve for a slick mounting location.. might have already been done but I have never seen it. Going to pull the third brake light off topper since its not being used and put a 6-8" single row bar in its place (if i can find one that is a flood light with the right mounts).
  8. Oct 2, 2017 at 10:56 AM
    Muddinfun
    I hope you didn't buy the Sylvania LEDs from your local auto parts store. If you ordered the Deauto bulbs, I can assure you that you will be blown away by how much light they put out.
    crashnburn80 likes this.
  9. Oct 2, 2017 at 12:33 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Key-Rei likes this.
  10. Oct 2, 2017 at 2:51 PM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    My Tacoma had the factory tow package and I tapped into the backup lamp circuit at the seven way connector for my LED aux lamp. No switch, light goes on when I'm in reverse. Very bright "flood" pattern.back up light.jpg
    RANGER13, 17taco4x4, Key-Rei and 7 others like this.
  11. Oct 2, 2017 at 4:21 PM
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
    Those LED's are cool looking. :thumbsup:
    What is the brand name/manufacturer of those slim line LED lights?
    Can you post pictures of them in use, such as in a dark road with them on then off?
  12. Oct 2, 2017 at 4:30 PM
    4r_to_taco
    florida, east coast
    @Muddinfun
    Yea, I went cheap and quick because im tired of not being able to see well behind me when backing up.. they have to be better than what was already there..
    @jbrnigan
    I will have to consider hooking in the way you did.. torn on having a switch for varied use though..
  13. Oct 2, 2017 at 4:40 PM
    Bocsy44
    Bocsy44 Well-Known Member
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    This that and the other thing.
  14. Oct 2, 2017 at 9:44 PM
    Muddinfun
    Nope. They're junk. Of all the money I've spent on my Taco, the only purchases I regret are the Sylvania LEDs. They're sitting on my desk now as a reminder to always do research before buying. Although some people praise the Home Depot bulbs, I'm telling you, the Deauto LEDs put out a ton of BLINDING light.
  15. Oct 3, 2017 at 7:38 AM
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    Reverse Light.jpg These are attached to the towing package reverse light circuit. It shares the fuse for the regular back-up lights so no advantage power wise.
    highriserkaiser likes this.
  16. Oct 3, 2017 at 7:50 AM
    Clearwater Bill
    Billy
    Largo Florida
    Is that protective mount something you made or came with that light?
    I have a pair of Crees waiting to install. While I don't off road in very harsh conditions, I wouldn't mind having a bit of protection for them.
  17. Oct 3, 2017 at 7:56 AM
    Ricky B
    Ricky B Well-Known Member
    Arkansas
    1998 XCAB
    SAVING THIS FOR LATER
    ChadsPride likes this.
  18. Oct 3, 2017 at 8:53 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
  19. Oct 3, 2017 at 8:54 AM
    outxider
    outxider Never stop exploring. Rest in Paradise Big Bro.
    Sang
    East Bay, CA
    06 DCSB 4x4
    A few mods here and there and counting....
    Bright and useful.
  20. Oct 3, 2017 at 9:06 AM
    highriserkaiser
    highriserkaiser Estoy Grifo
    Gunnison National Forest
    2007 DCSB TRD Offroad 4x4
    How can I identify that circuit? Putting this "mod" on my list.
