Wiring for extra reverse light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 4r_to_taco, Oct 1, 2017.
  1. Oct 3, 2017 at 9:28 AM
    outxider
    outxider Never stop exploring. Rest in Paradise Big Bro.
    Sang
    East Bay, CA
    06 DCSB 4x4
    A few mods here and there and counting....
    I can't remember the wire off the top of my head, i wanna say its white but i could be wrong. I put the truck in reverse and used a multi meter at the 7pin to determined which wire was hot when reverse was engaged. Uber simple and quick. The other option is to tap into one of the reverse wire at the one of the taillights.
  2. Oct 3, 2017 at 10:10 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    If im not mistaken the flip up cap of the original 7 pin has which wire is what.
    highriserkaiser likes this.
  3. Oct 3, 2017 at 10:32 AM
    4r_to_taco
    4r_to_taco [OP] Well-Known Member
    florida, east coast
    2006 double cab trd off road
    rear diff breather extension, slotted/cross drilled brakes
    @GREENBIRD56
    What brand light do you have? I dont want to spend a ton of money on a light to put on my topper in case I am not happy with it..
  4. Oct 3, 2017 at 11:07 AM
    outxider
    Sang
    East Bay, CA
    06 DCSB 4x4
    Conveniently the pins are labeled inside the 7 pin if you flip the cap open, ie brake, reverse, ect. I just doubled checked w the multimeter to be sure.
    Key-Rei and highriserkaiser like this.
  5. Oct 3, 2017 at 11:25 AM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    I think I'm going this route instead of changing bulbs. The stock light set up casts bumper shadows that likely wouldn't be eliminated just more pronounced.
  6. Oct 3, 2017 at 11:59 AM
    highriserkaiser
    highriserkaiser Estoy Grifo
    Gunnison National Forest
    2007 DCSB TRD Offroad 4x4
    Copy that. I might have to get this done before winter. Thanks.
  7. Oct 3, 2017 at 1:11 PM
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    here is the pin-out of the 7 pin that came on my 014:
    the light was marked "Kawell" - came off of epay. the steel housing is a piece of 1-3/4 leg angle with a piece of 1-3/4 flat bar welded on to make a deep "channel" shape. its bolted on the bumper and the bracket that originally held the trailer socket.
    Key-Rei and outxider like this.
  8. Oct 3, 2017 at 3:46 PM
    Bocsy44
    Bocsy44 Well-Known Member
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    This that and the other thing.
    what he said down below lol its perfect.
  9. Oct 3, 2017 at 3:58 PM
    highriserkaiser
  10. Oct 3, 2017 at 5:46 PM
    Clearwater Bill
    Billy
    Largo Florida
    12v circuit tester or a DVM should do it.
  11. Oct 3, 2017 at 7:08 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
    You mean DMM? Or see which color wire goes to the reverse lights if you have neither test capability. I agree that mounted low is good though I would rather flush mount in the bumper than hang it lower to be torn off or damaged.
  12. Oct 4, 2017 at 6:26 PM
    Trucks!
    Trucks! Something Clever
    The Woods
    2023 TRD Offroad DCSB MGM
    So does anyone know what the maximum safe total wattage/amps you can get from the reverse pin in the trailer plug would be? I have a 90watt LED light bar that I was thinking of sticking on a trailer hitch and actually plugging it into the trailer connection for removabĺe plowing light. Would the auxillary pin provide more power? I'd stick an inline fuse on the plug I would fashion for the light. Seems like too much to me. Running stock reverse lights now.
  13. Oct 4, 2017 at 9:02 PM
    Muddinfun
    Muddinfun Well-Known Member
    There is a single 10 amp fuse that feeds the back up lights and the turn signal flasher, so I'm guessing that adding another 6 amps is probably not a good idea. There is a 30 amp fuse that feeds the battery charge terminal in the trailer light connector. If I were doing it, I would do 7 pin connector>waterproof relay>LED light bar. Use the reverse terminal to energize the relay. Connect the relay contacts to the battery charge wire and to the light bar.
    GM cars and trucks are a good source for waterproof relays. Go to the wrecking yard and open a few hoods. Chop out the wires, connector, and relay.
    http://www.customtacos.com/tech.old...toyewd/06toypdf/ewd/2006/tacoma/h/em01d40.pdf
    Key-Rei and Ruffus like this.
  14. Oct 5, 2017 at 4:07 PM
    Atlas86
    Atlas86 Well-Known Member
    Ontario
    2012 Tacoma TRD Sport DCLB
    I recently did one on the bumper, need to do one on the other side. Wired to reverse light.
    vssman likes this.
  15. Oct 5, 2017 at 4:45 PM
    #35
    nd4spdbh
    SoCal
    does anyone have a line on an led pod (flush or not) that is not the standard cool blue white, but more of a warm white (4500-5000k)?
  16. Oct 5, 2017 at 4:52 PM
    #36
    Trucks!
    The Woods
    Thanks for the info. Maybe I'll use this 9" bar somewhere on the front and either get a couple 18w cubes for the back...or maybe just an outdoor worklight, plug it into the bed 100W/400W outlet, screw it to a bracket on the bed rail and aim it out the back...I'm a sucker for simple.
  17. Oct 5, 2017 at 5:30 PM
    #37
    rowan
    rowan Well-Known Member
    Victoria B.C.
    2014 Tacoma
    Nice Ass! I want it! Love those taillights
  18. Oct 5, 2017 at 7:01 PM
    #38
    Atlas86
    Ontario
    Haha thanks!
  19. Oct 5, 2017 at 7:33 PM
    #39
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Ive got pods in the bumper also. More than happy with them.
    4r_to_taco[OP] likes this.
  20. Oct 5, 2017 at 7:59 PM
    #40
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I have two ebay flood light pods mounted on the rear bumper step, they wouldn't last long if they were mounted below the bumper. I put them on a separate switch and I'm glad I did, great for hooking up a trailer or lighting up behind the truck when you drop something, want to pack up at the end of the night, night time recovery operations, and navigating the campsite when you need to pee at 3am. As a counter argument, I feel like a mega dick when I use them to back up or when I offroad then forget to turn them off back on tar. Counter counter argument, when you got some dick in his ricer with HID's in his reflector housings tailgating you it's nice to be able to flip them on and give them a taste of their own lumens. :rofl:
    My switch is in the cab but I'm trying to work out a secondary switch for the bed. Not sure how to wire a DC half hot circuit though... May have to run power to switch and then switch back to original relay.
    Stupid auto balance phone cammera doesn't do them justice, while the optic and spread isn't as nice as my rigids they are almost as bright. But that's why I have rigids up front and ebay in the back. 20170907_211531.jpg
    #40
