Wiring for Rear Differential Lock Switch
Discussion in '2nd Gen. Tacomas (2005-2015)' started by skydiver32, Nov 17, 2008.
  1. Nov 17, 2008 at 3:54 AM
    skydiver32
    skydiver32 [OP] New Member
    i have an 07 Taco w/TRD Sport Package. While changing the LED's in my cluster, I learned that the wiring for the rear differential lock is installed. Could I just install the switch and enable this capability?
  2. Nov 17, 2008 at 4:05 AM
    RCBS
    RCBS Well-Known Member
    Harden your bark, there are storms on the horizon.
    wrong rear end. you have 8.4". locker only on 8.0". sorry.
  3. Nov 17, 2008 at 4:43 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    No
    You'd have to change out your rear differential carrier plus there could be other things that need changed or added to make it work.
    You could remove the mech LSD (if this applies) and put in an aftermarket locker, but it'd be easier to wire it up separately.
