wiring for turn signal help
Discussion in '1st Gen. Tacomas (1995-2004)' started by donlogan, Feb 9, 2018.
  1. Feb 9, 2018 at 6:56 AM
    donlogan
    donlogan [OP] Well-Known Member
    I made a previous thread after I hit an ice patch and hit a guardrail with my 95 2.4L Yota.
    I was convinced by the posts there that the repairs were doable for a reasonable price tag. I'm going to take off the fender and bumper today. While I was taking a closer look at the damage I noticed that the wire that connects to the turn signal got cut. There are two wires that go into the connector part, one of them is no longer attached.
    How much of a pain in the ass is the fix for this going to be? I'm looking on Rock Auto for the part but can't seem to find the right one.
  2. Feb 9, 2018 at 7:04 AM
    robupstateny
    robupstateny Well-Known Member
    Rob
    Upstate NY
    2003 Lunar Mist Tacoma DLX
    Gray wire mod, Gentex 177 mirror, cupholder from @bradrn22, custom dog seat., AJT Design shift knob., Cb install
    Not sure if this is the right one but here's some part #'s for the turn signals.
    81515A - PLUG ASSY, FRONT TURN SIGNAL LAMP
    90075-99092
    ( 2 )TYPE A:REFER TO ILLUSTRATION(01/1995 - 02/2000)
  3. Feb 9, 2018 at 7:11 AM
    donlogan
    ^that's for the light that sits in the bumper. I'm looking for the turn signal light that sits next to the headlights.
  4. Feb 9, 2018 at 7:23 AM
    robupstateny
    Rob
    Upstate NY
    http://japan-parts.eu/toyota/us/
    try here. Plug in your VIN # information and go to the electrical tab. Should at least get you the part numbers you'll need.
  5. Feb 9, 2018 at 7:26 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    that's just a corner marker light. That being said, I believe that/s just a 194 bulb connector. When you purchase a new corner light assembly, it should come with one.
    Here ya go OP: https://www.ebay.com/itm/Corner-Lig...Tacoma&hash=item5681a1d9d5:g:9RUAAOSwmuVacayI
    You will likely have to get those other odd clips from the dealer. But you could always just get the part # and then see if there's anything on ebay.
  6. Feb 9, 2018 at 7:46 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
  7. Feb 9, 2018 at 7:48 AM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    What comes with corner light assembly is just the bulb socket
    looks like he'll need the pigtail as well
    it's attached to the wiring harness, but no need to change it, as you can snip one off a junkyard car and graft it to your wiring harness instead
    You can get it fom old corollas and camrys. I'm sure they do have the same connector somewhere for the lights
    Part number for bulb socket: 81615-04010
    so starting from that, try to find the compatible pigtail connector or a car that uses the same socket
    ThunderOne[QUOTED] likes this.
  8. Feb 9, 2018 at 7:52 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I've ordered a few sets of corners and each time they came with new bulbs and new sockets. You just have to wire up the socket, which I never bothered to do. Since OP has to get new corners anyways, might as well just see if they come with sockets first. I am pretty sure they do.
    I would mail some to OP because I'm pretty sure I have some, but they're at my other house
    mechanicjon likes this.
  9. Feb 9, 2018 at 8:14 AM
    tony2018
    tony2018 Well-Known Member
    What you're asking for is the parking like. Turn signals are on the bumper.
  10. Feb 9, 2018 at 4:41 PM
    donlogan
    So the 'wiring up the socket' part is a simple job? That was my main concern. I'm not a complete novice when it comes to working cars but didn't want take on something that will be a pain in the ass.
    So for the wiring part I'm assuming you basically take the wire and shove it in the socket :confused:
