Wiring from bed of truck into Cab - Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cell4130, Jun 7, 2010.
  1. Jun 7, 2010 at 2:05 PM
    Cell4130
    Cell4130 [OP] Member
    Georgia
    08 PreRunner SR5
    Im sure its been covered, but Ive searched and cannot find it, so I'm sorry in advance if this has been answered 200 times.
    Im wiring up reverse sensors, and the box the sensors lead to needs to be inside the cab. The wires come from the bumper, up into the tail light section, then through the side of the bed where the little cubbies are, then out a tiny hole at the hop of the bed, right before the cab. Here is where I got stuck, I could not find any hole to wire them through at this point. Any help would be appreciated.
  2. Jun 7, 2010 at 2:08 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    There are several rubber plugs/grommets underneath the cab.
  3. Jun 7, 2010 at 2:09 PM
    TicTacOma
    TicTacOma UnderWater Monopoly Champion
    Anastatia Beaverhausen
    Columbia,SC
    I'm Thinking...Oh Yeah...An FJ
    It's all in my head at the moment...
    Welcome to TW. Under the driver's side rocker panel (under the driver's seat area), follow where the emergency brake cable enters the cab. Use that grommet. then pull up the plastic trim that runs along the outer side of the driver's seat floor area and the kick panel. Should clean up nicely.
  4. Jun 7, 2010 at 2:11 PM
    TaComatoseSR5
    TaComatoseSR5 Mud Junkie
    Stephen
    Tampa, FL
    White 05' SR5 Access Cab 3" lift
    3" Toytec lift (coils and aal), 285/75/16 terra grapplers, HID conversions,led taillights, grillcraft grill, on board air with air horn
    i drilled a hole thru the floor near the rear of the cab and siliconed around the wire
  5. Jun 7, 2010 at 2:13 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    these. I ran power wires for back up lights and used one of the little rubber grommet holes. there are a few under there.
  6. Jun 7, 2010 at 2:19 PM
    Cell4130
    Georgia
    08 PreRunner SR5
    Appreciate the fast replies... I found another thread with photos of a CB coax cable being wired that helped. Thanks!
