Wiring Gurus? Need advice!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Outdoorsy_Yota, May 2, 2019.
  1. May 2, 2019 at 10:08 AM
    Outdoorsy_Yota
    Outdoorsy_Yota [OP] Hella-Known Member
    duhbondo JIW Local 378
    Bay Area
    17 DCLB TRD OR LOL
    Running dual batteries. Fuse block and accessories wired to the accessory battery. But the ground from the fuse block is ran to my starter battery (out of convenience). Will this drain my start battery when the accessories are sucking the accessory battery? Or should I run the fuse block ground to the accessory battery as well?
  2. May 2, 2019 at 10:14 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    Not a "Guru", but instinct tells me that NOTHING should be anywhere near the original electrical system.
    G.
  3. May 2, 2019 at 10:16 AM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Start battery will only drain if the positives are connected.
  4. May 2, 2019 at 10:16 AM
    Outdoorsy_Yota
    Bay Area
    17 DCLB TRD OR LOL
    Yeah, makes sense the more I think about it. I’ll most likely end up running a separate ground to the accessory battery and leave the start battery factory
    bagleboy and Garyji[QUOTED] like this.
  5. May 2, 2019 at 10:18 AM
    Outdoorsy_Yota
    Bay Area
    17 DCLB TRD OR LOL
    Spent a pretty penny on Northstar AGM batteries and I want to make sure I maximize the efficiency. Thanks, man
  6. May 2, 2019 at 10:21 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    It's the same shit. If it's grounded to battery or frame, they're still both connected.
    Outdoorsy_Yota[OP] likes this.
  7. May 2, 2019 at 10:21 AM
    bagleboy
    Scott
    Norcal, Santa Rosa
    Do this instead. It's not absolutely necessary but a lot of grounding issues can be avoided by having ground returns to a common buss connected to battery neg. Don't forget a high current breaker for the main auxilary fuse panel.
  8. May 2, 2019 at 10:23 AM
    bagleboy
    Scott
    Norcal, Santa Rosa
    The grounds are but each battery powers separate systems. Unless the two positives get connected using one system won't drain the other.
  9. May 2, 2019 at 10:25 AM
    Outdoorsy_Yota
    Bay Area
    17 DCLB TRD OR LOL
    I have the breakers and an isolator... just was curious if the start battery could somehow drain through the Neg terminal as the accessories pull power from the acc. Batt
  10. May 2, 2019 at 10:26 AM
    Outdoorsy_Yota
    Bay Area
    17 DCLB TRD OR LOL
    Thanks
  11. May 2, 2019 at 10:28 AM
    bagleboy
    Scott
    Norcal, Santa Rosa
    If you charge the second battery from your alternator then the positives are connected. If you want to avoid overdischarge of the start battery install an isolator switch to separate the systems when parked and using auxilary power. Edit-just saw your last post -you should be gtg then.
  12. May 2, 2019 at 10:29 AM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Yap.
  13. May 2, 2019 at 5:40 PM
    Tofuma
    Tofuma Active Member
    Tony
    San Francisco
    2019 Cement Grey TRD OR DCLB
    Seems like everything is wired up correctly. I would just make sure both negatives have an independent wire going back to chassis.
  14. May 2, 2019 at 6:27 PM
    Outdoorsy_Yota
    Bay Area
    17 DCLB TRD OR LOL
    Never even thought about adding a ground to chassis on the accessory battery. Thanks! Right now the ground is going back to the isolator
