Wiring harness 2019 Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DD430, May 13, 2023.
  1. May 13, 2023 at 2:54 PM
    DD430
    DD430 [OP] New Member
    I had a check engine light come on last week indicating a problem with the low pressure side of the fuel system. I suspected that the fuel pump had gone bad. Since I've already had the fuel pump replaced under warranty I had the truck towed back to the dealer. They confirmed the codes and put in another pump. When they tried to start the truck - same problem, same codes. They checked back to the relay and found power but nothing through the wire at the pump. They then put a jumper in line and the pump fired up. They've diagnosed it a bad wiring harness. The truck has had a babied life - no off-roading, no driving through deep water, no accidents, and no rodents chewing on wires. They tell me that it's a cab-off job that will cost about $3,000.00. I searched the forum and didn't find any similar problems. Have you guys seen anything like this?
  2. May 13, 2023 at 3:28 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I’ve never heard of a wiring harness failing on its own. I’d ask for pics and understand where and why it’s damaged.
    A few questions I’d thinking of:
    Did the factory damage on assembly?
    Did the dealer damage it when they did the fuel pump?
    Do they not know where and why, and an entire replacement on you dime is what benefits them most?
  3. May 13, 2023 at 3:37 PM
    DD430
    Yeah, I asked them to save the harness for me. I want to check it out.
  4. May 13, 2023 at 3:45 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    I’m skeptical; the only thing that’s been touched on this truck (presumably) is the fuel pump, and now the harness randomly fails, and it’s the fuel pump wire?
    I’d have someone else look at it. If the dealer damaged it doing the recall work they wouldn’t get reimbursed by Toyota. Any damage they cause would be out of their pocket, So they don’t have any incentive to find the cause.
    wayupnort likes this.
  5. Jul 17, 2023 at 6:57 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
