Wiring Harness 98 engine swap
Discussion in 'New Members' started by foscycle, Oct 13, 2024.
  1. Oct 13, 2024 at 11:26 AM
    foscycle
    foscycle [OP] New Member
    Hi, I am new to this forum. I have two 1st gen Tacomas. I am swapping a 1998 2.7 engine into my 2001 2.7 4-wheel drive manual transmission truck. I have the wiring harness for the engine however this the ECU has other plugs that don't fit properly. Does this mean that I have to also replace the wiring harness for the cowl and any other wiring harnesses? It's difficult for me to find the exact year harness. It would be nice if I didn't have to replace the cowl harness. Any advice on this one?
  2. Oct 13, 2024 at 11:42 AM
    foscycle
    Alternativly would it be a better plan to simply switch the parts of the engine to make it similar to a 2001 2.7 engine (even though it is a 1998 engine) so I can use my 2001 wiring?
  3. Oct 13, 2024 at 11:44 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Yes. Swap the parts.
    The harness won't always work.
    The harness may be pinned differently than your ECM.
    Always better to swap parts if you can.
    buckhuntin-tacoma likes this.
  4. Oct 13, 2024 at 11:48 AM
    foscycle
    So the parts that would need to be swapped are those related to the ignition? Sorry learning all this as I go.
  5. Oct 13, 2024 at 12:11 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
