wiring harness for fog light switch
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ralvarez527, Feb 13, 2012.
  1. Feb 13, 2012 at 10:21 AM
    Ralvarez527
    Ralvarez527 [OP] Member
    Raf
    New York
    08 tacoma T.R.D.
    Hey wats going on its my first time using this thing, but im curious if anyone has or know where i can purchase a wiring harness for the rear of the fog light switch, already have the switch just need the back harness. Trying to keep the stock look. Thanx
  2. Feb 13, 2012 at 10:27 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    I've got one that came with a retrofit that I did (it was the wiring harness from The Retrofit Source. It should have the same connection for the OEM fog lights (I can confirm when I get back home). It's got everything you'd need besides the switch and in-line fuse (relays, wiring with enough length to make the runs and the plugs). If it's the right connection, I'll sell it for $10 shipped to you. If you want it, let me know.
    Otherwise, you could probably get just the connection at an autoparts store such as Napa, Autozone or Advanced.
  3. Feb 13, 2012 at 10:44 AM
    Ralvarez527
    Raf
    New York
    08 tacoma T.R.D.
    Yeah that would be awesome. let me know wat i would have to do to get it started. thanks man
  4. Feb 13, 2012 at 10:55 AM
    Pugga
    Massachusetts
    F-150 Mod
    Crap, hold on, I misread your post... I thought you were looking for the rear of the housing (where the bulbs plugs in). Sorry, read it too fast :eek:
    If you already have a fog light switch, you don't need a harness, just connect directly to the switch's prongs sticking out the back. It's a little tedious, but it does work.
    From the top of the switch, here's the order you'd need to connect things to it:
    1. Top - ground
    2. Power input
    3. Illumination power
    4. Bottom - Power output
  5. Feb 13, 2012 at 11:35 AM
    Ralvarez527
    Raf
    New York
    08 tacoma T.R.D.
    No problem. The thing is i installed 4 hella off road lights and ran them to a flip switch, with a positve and negative wire. i figured if i get the harness i could splice the wires and connect it directly to the switch. How would i directly attach the two wires into the 4 prongs
  6. Feb 13, 2012 at 11:43 AM
    Pugga
    Massachusetts
    F-150 Mod
    Your positive wire coming in would go to #2 - Power Input, the Negative (or ground) would go to #1 - Ground. #4 is your power output going to the lights when the switch is on and #3 you can pull where ever you want. #3 powers the bulb inside the switch so, for a factory look, you'd need to tap into a circuit that's hot when the lights are turned on (that way the switch lights up when your lights are on). Even with the harness, you're still going to have 4 wires to run, it's just easier to connect them to the switch at the end.
    You can attach the wires using small female connectors or by soldering directly to the switch's tabs.
  7. Feb 13, 2012 at 12:31 PM
    Ralvarez527
    Raf
    New York
    08 tacoma T.R.D.
    Okay awesome. Thanks man i appreciate all the help ill post some pics of the lights in a few.
  8. Mar 9, 2012 at 1:49 PM
    gb11tacoma
    gb11tacoma Member
    george
    somerville,mass
    tacoma4X4
    thanks alot,i just bought the switch and connector on ebay and the dealer didnt know where the wires went for my fog lights in a 2011 toyota tacoma.......
  9. Mar 9, 2012 at 6:52 PM
    Pugga
    Massachusetts
    F-150 Mod
    Fog lights shouldn't be pushing 10 amps :confused:
    45W fog light bulbs would only draw 7.5 amps. You're right though, the lower amperage you could put through the switch, the better.
  10. Mar 9, 2012 at 8:13 PM
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    Since he said he was running 4 hella offroad lights through the circuit, he might need to worry about that 10 amps.
