Wiring Harness for Tacoma LED headlights
Discussion in 'FBC Harness Solutions' started by 49er83, Aug 4, 2022.
  1. Aug 4, 2022 at 5:46 AM
    49er83
    49er83 [OP] New Member
    Hi Dave. I was wondering how I can purchase a wiring harness from you. I just bought the headlights, part # 81150-04290 and81110-04290 and will need the harness. Thank you
    Tacospike likes this.
  2. Nov 11, 2022 at 7:56 AM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
  3. Nov 11, 2022 at 9:14 AM
    hahnster
    hahnster Well-Known Member
    2022 Tacoma 4x4 V6 AT
    3" Lift, TRD Pro Grill, TRD Skid Plate, 285x70/r17 BFG KO2's, LED Headlights, Rock Sliders
    Hi Dave. Will the sr sx harness work to convert my halogen headlights and allow me to install the trd pro headlights part numbers:
    Part Number:81110-04300(Right
    Head Light that says TRD)
    81150-04300(LeftHead Light That says PRO)
    just want to make sure because the headlights are expensive and the vendor is saying nobody makes a harness. Appreciate the help.
  4. Nov 11, 2022 at 9:16 AM
    Puppypunter
    Puppypunter Well-Known Member
    Johnny
    2019 Black SR
    It will. The harness is definitely good, but I know Dave does some added goodies to the different kits, so I’ll let him verify which one :)
  5. Nov 11, 2022 at 10:15 AM
    daveeasa
    David
    PNW
    Only one version of the SR /SR5 harness.
    JOEHYDRO likes this.
  6. Nov 12, 2022 at 2:02 PM
    Wpg.Tacoma
    Wpg.Tacoma New Member
    Arthur
    2018 Tacoma TRD
    Hi Dave, i am looking to order the wiring harness DIR for my 2018 tacoma. Tried ordering from your FBC Harness Solutions but my address is not being accepted, Winnipeg Manitoba Canada. if you cant ship here then only in USA?
  7. Nov 12, 2022 at 4:37 PM
    daveeasa
    David
    PNW
    Yeah, I stopped shipping to Canada, sorry. Too much trouble for me.
  8. Nov 17, 2022 at 4:58 AM
    JOEHYDRO
    JOEHYDRO New Member
    Joe
    2022 Toyota Tacoma access cab 2.7L
    Led fog lights, lund fender flares, aftermarket tow hitch, led bed lights, hard top bed cover, rubber bed rug, aftermarket 17" wheel rims and Kumho MT51 tires.
    Hi Dave,
    I have a 2022 Taco SR and swap for the LED headlights. I'm trying to buy one of your harnesses in your site but it says that my address is not supported, and changes Puerto Rico in the box next to the phone input to Canada. Can you fix this?
    Please, let me know how can we proceed, you can ship USPS Priority like any other continental state.
    I live in Puerto Rico, 00949. But your site changes my country to Canada, ???
  9. Nov 17, 2022 at 6:27 AM
    daveeasa
    David
    PNW
    Yeah, square sucks doesn’t it? I’ll start a DM
  10. Dec 4, 2022 at 6:35 PM
    CAG Gonzo
    CAG Gonzo Ascendant Spaghetti
    2018 OR DCLB BarRed
    Hello, I've got the LEDs arriving soon. I have a 2018 TRD OR and am tracking the harness I need to get, but have a question as to the variant. I have some DD SS3s that I'll install as fog lights at the same time as the headlights. They have the back light feature.
    So I'd want the dual output LED harness as well as the 2 x 12" fog light harness option? Do the fog light harnesses connect directly to your dual output LED harness? I ask because the description of the fog light harness mentions a 1 x12" and 1 x 60" option for connecting both to the driver side and am confused as to which setup I need. Thank you!
  11. Dec 7, 2022 at 8:20 AM
    get-er-dirty
    get-er-dirty Well-Known Member
    J
    Black 17 SR5
    Hi Dave,
    Do you have a harness to convert my SR5 headlight to a set of Tacoma Headlights with DRL on 2018 TRD Pro. I want to stay somewhat stock.
  12. Dec 7, 2022 at 8:31 AM
    daveeasa
    David
    PNW
    I sell an SR / SR5 SX to OEM LED conversion harness (but sold out just today).
    I do not make a harness for TRD Halogen headlights on an SR, that's not an upgrade and not worth doing, just a different "look".
    redneck pilot likes this.
  13. Dec 7, 2022 at 8:55 AM
    get-er-dirty
    J
    Black 17 SR5
    Thanks for the quick update. Would you be willing to help show me where you get the connectors and if you have a part number? I will try to make a set and hopefully not blow up anything LOL
  14. Dec 7, 2022 at 8:59 AM
    daveeasa
    David
    PNW
    It's not easy to do b/c the SR has combined DRL and Turn on a single wire. Changing to an LED board for DRL and a discrete bulb for Turn requires a solution to de-multiplex those signals. We use a relay and a timer, hence the $200 purchase price for OEM LED conversion. It's effectively the same requirement with halogen TRD Headlight conversion harnesses for no net gain, hence I don't spend any time building them.
    I strongly advise against doing what you are doing, spending lots of time and money for the same crappy halogen headlights you already have. Go OEM LED.
  15. Dec 7, 2022 at 9:05 AM
    get-er-dirty
    J
    Black 17 SR5
    OK, gotcha I appreciate your thoughts. I will go in a different direction.
  16. Dec 7, 2022 at 9:07 AM
    daveeasa
    David
    PNW
    But I will identify the connectors for you. The TRD Halogen headlight will effectively use the same connectors as the TRD OEM LED conversion harness:
    https://www.tacomaworld.com/threads/oem-led-conversion-harness-diy-info.700623/
    So, to build out an adapter harness from SR to TRD halogen you'd need these two connectors as outputs:
    DRL: https://www.corsa-technic.com/item.php?item_id=992
    Turn: https://www.corsa-technic.com/item.php?item_id=899
    Sidemarker, low and high beam connectors are unchanged.
    To interface with your SR OEM harness you need one of these:
    https://www.corsa-technic.com/item.php?item_id=1041
    Which is the same style as used in the turn signal location at the rear taillight (fun fact). You can visually confirm this part with your truck as well. It's a standard 3 wire Toyota bulb connector, used for quite some time (same style on my '02 Tundra and '05 Tacoma)
  17. Dec 7, 2022 at 9:24 AM
    get-er-dirty
    J
    Black 17 SR5
    Thank You:thumbsup:
  18. Dec 7, 2022 at 9:54 AM
    daveeasa
    David
    PNW
    Oh, and also, pinouts for SR 3 position are
    1 == DRL + Turn
    2 == Park
    3 == Ground
    For the TRD DRL and Turn connectors, refer to the DIY thread and photos.
    If you were to connect SR DRL + Turn to both turn and DRL directly on the TRD Halogen headlight, your turns would be illuminated with DRL. So, one thing you could do is turn DRL off in the head unit settings and use add-a-fuse on INJ to send DRL to your DRL board, thus forcing it to be always on.
    Outside of that you really must de-multiplex somehow and Johnny has invested a lot of time figuring out the best way to do that with a lot of potential solutions. We've settled on the "easy install" option for now as the best plan but there are ways to get more of a TRD behavior (no startup turn flash when turning on DRL the first time) with added install difficulty.
    TLDR: This is not a great beginner project, it's much more challenging that it might appear and for the time spent you'll just be so much happier going OEM LED.
    Now, I will mention that the morimoto xb v2 is available with an SR/SR5 harness and I believe will work (Intergerdy has that setup). I am personally not a fan due to the lack of uplight but I will mention that option for completeness.
    My advice is OEM LED and the SR/SR5 conversion harness, 2-4 hours to swap them out, and you're good for 25 years.
  19. Dec 7, 2022 at 9:29 PM
    TacoMan321
    TacoMan321 New Member
    Will auto high beams work correctly with this harness?
  20. Dec 8, 2022 at 2:52 AM
    redneck pilot
    redneck pilot Well-Known Member
    North Texas
    2023 SR TSS Off-Road 4x4
    I’m watching this thread and will purchase an SR harness when they become available again. Coming from Lexus triple beam headlights to these SR lights sucks!
