Wiring harness not for use on JBL/amplified systems?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cutter_, Apr 24, 2017.
  1. Apr 24, 2017 at 10:53 PM
    Cutter_
    Cutter_ [OP] I probably could have googled this
    2002 Super Air Nautique Build
    Old Man Emu lift, 2 10" JL subs
    i got a 10$ schosce wiring harness from Walmart and I noticed it says (non amplified, non JBL). I'm just doing a head unit right now but does that mean I can't drop in an amplifier at a later time with this harness installed?
  2. Apr 25, 2017 at 3:37 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    I think that means it wont work on a factory amplified system
  3. Apr 25, 2017 at 4:35 AM
    Indy
    Indy Master of all I survey.
    Yep.
  4. Apr 25, 2017 at 4:59 PM
    Indy
    Wire colors are arbitrary, just because they match doesn't mean they should connect and just because one had a stripe doesn't mean it shouldn't.
    There are general colors used for the same thing but it's not guaranteed especially if you do installs on multiple vehicle makes and ages. Just match up the diagram and the harness.
    In general red is switched +
    Yellow constant +
    Blue remote turn on, power antenna
    Orange illumination
    Black ground
