Wiring harness problems
Discussion in '1st Gen. Tacomas (1995-2004)' started by davidk0, Jul 3, 2012.
  1. Jul 3, 2012 at 6:38 PM
    davidk0
    davidk0 [OP] Well-Known Member
    sacramento
    95 SR5
    I have a 95 manual 4x4 tacoma... My select switch does not engage the 4x4, so i went to a proffessional auto electrician and he tells me that i have the wrong engine harness on it. He said my harness is for the manual transfer case with high 4 and low 4 but my actual transfer case is auto select switch with the high and low 4. Any way i can manually make the 4x4 work or is anyone selling a harness with the select switch harness on their wiring harness? Please help
  2. Jul 3, 2012 at 6:41 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Time to start calling the wrecking yards (my second home)
  3. Jul 5, 2012 at 10:51 AM
    davidk0
    sacramento
    95 SR5
    Got any phone #??? I called a few they don't have what I need.
  4. Jul 5, 2012 at 4:32 PM
    hossmaster
    hossmaster Well-Known Member
    League City, Tx
    Was a PreRunner, now it isn't
    ok, so you have an electronic actuated transfer case and a fully manual front differential with manual lockout hubs? Yes you can easily make a setup to move the actuator from 4wd to 2wd and even wire in lights to show what position you are in. You basically install a switch that can reverse the polarity on two wires that make the motor spin one direction or the other.
  5. Jul 6, 2012 at 9:23 AM
    davidk0
    sacramento
    95 SR5
    Hossmaster, I have an electronic
    Actuated transfer case, as well as the differential. I am missing two plugs for the diff and one for the transfer case, the electrician told me I have the wrong wiring harness for the truck.
  6. Jul 6, 2012 at 4:03 PM
    hossmaster
    League City, Tx
    well your in a bit of a pickle. how did you manage to get this combo on the truck? Did you buy it this way from someone else? You could technically wire in the same type of switch to actuate the front diff that would be setup for the transfer case.
  7. Jul 7, 2012 at 8:44 AM
    davidk0
    sacramento
    95 SR5
    Yes I bought the truck
    This way. I guess I just need a new engine harness
