Wiring harness
Discussion in 'Lighting' started by doc1911, Jun 20, 2013.
  1. Jun 20, 2013 at 8:30 AM
    doc1911
    doc1911 [OP] Well-Known Member
    NC
    2004 TRD SR5 4x4
    A friend gave me a set of new Lightforce aux lights. It did not come with a harness. The Lightforce one is about 50$. Do I need to use theirs? Are all harnesses for aux lights basically the same? Where is the cheapest place to find one?
    Thanks
  2. Jun 20, 2013 at 8:37 AM
    StuckinOhio
    StuckinOhio Well-Known Member
    Mark
    Ohio
    12' v6 AC 4x4 SR5
    They are basically all the same. When wiring my HID Kragens I picked up a KC wiring harness off amazon for $30. Most wiring harnesses include a relay, inline fuse, switch and leads.
  3. Jun 24, 2013 at 6:16 PM
    doc1911
    NC
    2004 TRD SR5 4x4
    I found a Hella 500 harness for about $20. Any reason it will not work with a set of Lightforce 170 Strikers?
  4. Jun 24, 2013 at 10:33 PM
    acdronin
    acdronin Well-Known Member
    if the wattage on the bulbs is the same you should be fine
