Wiring heated seats with a fuse tap
Discussion in 'Technical Chat' started by Vicent-rodr, Jan 29, 2021.
  1. Jan 29, 2021 at 7:14 PM
    Vicent-rodr
    Vicent-rodr [OP] New Member
    2021 MGM TRD Sport
    265/70/17 falken wild peak at3w Icon rebound wheels
    Hey there, I had quick question. The heated seats I will be using are 5.03 amperage max. I was going to use a 10amp max fuse tap. Now, they gave me a power wire and a ground wire. I have an optional in line 7.5amp fuse and was wondering do I need that if I’m using a fuse tap?
    Next, I wanted to tap into an existing fuse that is 7.5 amps and then the new fuse would be 7.5 amps, would that be fine, to use the same amperage fuse in both slots of the fuse tap? If not would you recommend the original 7.5amps in the bottom slot and then 5 amps in the top slot, i don’t know if that would work as the seats would pull slightly over 5amps. Thank you so much
  2. Jan 30, 2021 at 11:22 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    The slot you tap for the fuse is rated for higher than the fuse that's installed, generally they would all be rated for the theoretical maximum fuse size you could install (likely 30 amp). You need to look at the upstream power from the 7.5 amp fuse and see the rating on that to ensure that adding 5 more amps to that circuit will not overdraw the rating on the upstream fuse to ensure proper fuse coordination. If you know the seats draw 5 amps, I would recommend the 7.5 amp fuse which would have been the same rating as the manufacture appears to also recommend since that is what they supplied.
    What 7.5 amp fuse in the truck did you want to use to tap the seats into?
    Wyoming09 likes this.
  3. Jan 30, 2021 at 2:04 PM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    If the 2021 is anything like the previous years of 3rd gen, there is already a fuse spot for the factory seat heaters (when equipped)
    Look at your fuse box cover and see if that spot exists on your truck (or post a picture so we can see it)
    If you have it, that would be the ideal location for your aftermarket seat heater fuse tap
    deanosaurus likes this.
  4. Aug 11, 2021 at 8:06 AM
    Wastah
    Wastah Member
    21 Sport MT
    Can anyone give me recommendation for where to buy aftermarket seat heating pads for 2021 Tacoma with rectangular switches that fit panel? Thanks
