Wiring Hella 500's to stock fog switch- Help
Discussion in 'Lighting' started by chieffan2, Mar 4, 2011.
  1. Mar 4, 2011 at 6:35 PM
    chieffan2
    chieffan2 [OP] Member
    Los Angeles
    westin side steps, black grille, oem skid plate, Pioneer AVIC-Z1000 Nav
    I want to wire my Hella's to work with the stock fog light switch. I already have the stock fogs intalled and working. I want the fog switch to turn on and off both the fogs and hella's together. Do I have to splice the wires or get a relay. Anyone know how to connect the two or know of a link on how to.
    Thanks
  2. Mar 4, 2011 at 8:12 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Did your hella's come with a wiring harness? Instructions? A relay? They usually do. If you have all these things, it's really simple. All you do is follow the instructions, but instead of wiring a switch you just take the one wire from the relay that should go to the switch and connect it to the positive wire going to the factory fog lights. Disregard the other wiring going to the switch in the instructions.
  3. Mar 4, 2011 at 8:15 PM
    chieffan2
    Los Angeles
    Perfect. Thanks for the info. I will try that.
  4. Mar 12, 2011 at 4:03 PM
    chieffan2
    Los Angeles
    Do I still have to run wires into the cab if I an not using the a switch.
  5. Mar 12, 2011 at 7:33 PM
    chieffan2
    Los Angeles
    Ok. Any suggestions on the best place to splice into the 86 wire?
  6. Mar 12, 2011 at 7:38 PM
    outxider
    outxider Well-Known Member
    Sang
    Bay Area
    06 DCSB 4x4
    A few mods here and there and counting....
    You tap into the harness coming out of the oem fog switch which requires running one wire off the hella 500's relay. I just finished wiring my hella 500s to a FJ cruiser oem switch, more work but I like in the independent control of the hellas and the factory look in the dash.
  7. Mar 12, 2011 at 7:43 PM
    chieffan2
    Los Angeles
    So do I have to go through the firewall? I am trying to avoid that.
  8. Mar 12, 2011 at 7:49 PM
    larryde09
    larryde09 Well-Known Member
    Larry
    Rochester, NY
    (Traded-in) 06 2.7L 5-spd SR5 4x4
    K&N Intake, Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars/sliders/running boards, DIY Bed Lights, DIY Running Board/Ground Lights, DIY Tailgate Electrical Box (12V socket, voltage and current gauges), DIY Internal Lighting (coming soon), Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    EDIT: -------------
    x2....I don't know if the bluegreen wire he's refering is in the cab or in the engine compartment, so just to clarify....
    No, if you want the hella's to turn on w/ the fog lights, here's the relay pin-out:
    30-fused power
    86-tap one of the power wires to a fog light
    87-to Hella power
    85-ground
    Check out my basic electronics thread for more info (link in my signature)
  9. Mar 12, 2011 at 8:09 PM
    chieffan2
    Los Angeles
    Got it. Thanks so much.
  10. Mar 12, 2011 at 9:39 PM
    SIKWAY7
    SIKWAY7 Active Member
    mark
    washington
    Tacoma Sport 09
    k&n air ram/filter- trd catback exhaust- trd quick shift- bilstein 5100- cb mod-flashlight mod-hella 500 lights- -trd skid plate-trd shift knob-igge black seat covers-dynamat floor,doors and back wall-etc.
    Getting ready to do in-grille lights. If your truck has an avaiable stock switch opening you might want to run your fog lights separate next to it. I have a 2009 tacoma.There was one available stock opening. Bought another factory stock switch and harness. Found switch on ebay (48.00) and bought harness for 17.95 at local dealer parts. Roughly 65.00 to set-up. Already have pre-wired done. Couple more patrs(bumper) and I'm to install. All gonna look like factory installed. Abit of an expense but i'ts worth it to me. Plus the switches sent in packagesaren't very good.
    Just my 2cents....Best to you.
  11. Mar 13, 2011 at 6:03 AM
    larryde09
    Larry
    Rochester, NY
    You're right, but I assumed the OP wasn't sure if the blue/green wire you mentioned is located in the cab or the engine compartment. I edited my original post to give you props ;)
