Wiring Hella 500s?
Discussion in 'Lighting' started by Jbcm12, Dec 16, 2012.
  1. Dec 16, 2012 at 9:54 PM
    Jbcm12
    Jbcm12 [OP] Well-Known Member
    Joshua
    Bay Area
    Tried my best all day to install, search on TW, and search on the Internet but I just don't hnderstand how to run these Hellas. The instruction manual is worthless, if I did everything g correctly from what I gathered I'm only missing the green wire which goes from the switch to a 12v something. I think it's a fuse but how do you do that?
  2. Dec 16, 2012 at 9:59 PM
    YFZ450MOE
    YFZ450MOE When you blow off steam you get an eyepatch
    Moe
    Auburn, WA / Roseburg, OR
    09 white DCSB TRD (it's getting there)
    Icon Extended Travel 2.5" Coil Overs All-Pro U-Bolt Flip Kit Bilstien Rear Shocks Fabtech Add-a-Leaf Icon Upper Control Arms All-Pro Rear Bumper w/ Wrap Arounds & Hitch with custom LED plate light BHLM and Morimoto III D2S retrofit Satoshi Grill 2 Hella Black Magics behind Grill Bestop Supertop BAMF sliders
    Take that to the battery. And if you have problems from there switch around the wires on the switch and it should work.
  3. Dec 16, 2012 at 10:14 PM
    Jbcm12
    Joshua
    Bay Area
