Wiring Hella 700ff behind grill
Discussion in 'Lighting' started by 709, Jun 19, 2012.
  1. Jun 19, 2012 at 5:04 AM
    709 [OP] Member
    Brad
    Newfoundland
    08 tacoma
    Hey everyone , I recently mounted two Hella 700ff's behind my grille and when I went to wire them up I had no luck! I followed the wiring diagram but for some reason the switch will not light up and the lights will not work. I've ran the yellow and green wite from the switch but instead of going green to high beams I just grounded it out because I want to run them on the switch only. Any help on why these aren't working?
  2. Jun 19, 2012 at 3:25 PM
    Hii
    Hii Well-Known Member
    Was the green that you grounded supposed to be tapped into the negative or positive of your hi beam?
    I'm gonna guess it was supposed to be to the positive?
    Take the green wire and run that one to your switch
  3. Jun 19, 2012 at 3:28 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
  4. Jun 19, 2012 at 3:29 PM
    YFZ450MOE
    YFZ450MOE When you blow off steam you get an eyepatch
    Moe
    Auburn, WA / Roseburg, OR
    09 white DCSB TRD (it's getting there)
    Icon Extended Travel 2.5" Coil Overs All-Pro U-Bolt Flip Kit Bilstien Rear Shocks Fabtech Add-a-Leaf Icon Upper Control Arms All-Pro Rear Bumper w/ Wrap Arounds & Hitch with custom LED plate light BHLM and Morimoto III D2S retrofit Satoshi Grill 2 Hella Black Magics behind Grill Bestop Supertop BAMF sliders
    I ran the green to my battery. My switch doesn't light up either but I did notice that the if the wires on the back of the switch aren't in the exact spot nothing works. I didn't tap into my headlights at all and the lights work with the switch only. Shoot me a pm with your number and I'll call you if you need any assistance
