Wiring help! Lock & unlock DRL flash relay
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ryrydtl, Nov 28, 2013.
  1. Nov 28, 2013 at 10:23 PM
    ryrydtl
    ryrydtl [OP] Well-Known Member
    Cailifornia
    2019 Tacoma Pro
    Hey guys, I ordered a Rigid Industries LED light bar for my lower bumper grille. I want the bar to come on (flash) with the DRL flash when I unlock or lock my truck. I am installing the bar with a wiring harness w/ relay just like any HID wiring harness. The bar (relay) will be triggered with a switch inside my truck, but I also want it to flash like I said before. I believe I can do this by tapping into the Toyota lock & unlock DRL flash relay and connecting it to the relay on LED bar wire harness with a diode inline so that when I turn on the bar via the switch, current will not travel back into the lock & unlock DRL flash relay. I dont want the bar on whenever my DRLs or blinkers or on, only with the alarm flash and via the switch. If someone knows what relay this would be can you please help? Or if you have any other ideas please let me know! thanks
