Wiring help please!
Discussion in '1st Gen. Tacomas (1995-2004)' started by madmax700r, Dec 30, 2017.
  1. Dec 30, 2017 at 7:03 PM
    madmax700r
    madmax700r [OP] Well-Known Member
    Washington
    98 4bt swapped on tons and 43’s
    wish I would have taken pictures before I pulled all this apart but can anyone tell me if the wire circled in red goes to the fuse box power stud??? 2D8FB6EF-C3C4-4E59-864F-577DCF1C2D2E.jpg
    And second what is plugged into these?? Can’t find any good info anywhere
    By any chance can someone take a picture for me please
  2. Dec 31, 2017 at 10:40 AM
    madmax700r
    Washington
    Anyone help a brother out??...
  3. Dec 31, 2017 at 12:29 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    First pic, that wire goes to the + battery terminal. "Feed" for the fuse box. Should be one more from the alternator/starter harness on that empty stud on the fuse box.
    Second pic, small circle. Alternator "control" wires also from alt/starter harness. Large circle, the 2 ADD VSV's. Reddish plug on the froward VSV blue to the rear.
  4. Dec 31, 2017 at 12:57 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Yup. I asked the same two questions about those two connectors under the fuse box and they're for the 4WD system VSV's.
  5. Dec 31, 2017 at 1:15 PM
    madmax700r
    Washington
    Awesome thank you guys! Hopefully I can get rid of the gauge cluster and have everything still work. Need to get some wiring diagrams. Just wasn’t sure if I could get rid of those VSV plugs or not. Appreciate it guys!
    Going to start wiring my truck here soon and try to get the lights/everything working with this 4bt.
  6. Dec 31, 2017 at 1:31 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    What wiring diagrams do you need? There's a post stickied to the top of this forum with 75% of all the Toyota FSM's for the first gen.
  7. Dec 31, 2017 at 2:48 PM
    madmax700r
    Washington
    I just grabbed a Haynes manual for like $20 so I have all the ones I need. I think..
    I looked at the sticky but the link won’t work for me for some reason.
    Just trying to get the heater, lights and radio to work. That’s really all I need
  8. Dec 31, 2017 at 2:52 PM
    Dirty Pool
    99 XCAB V6 MT TRD
    Not sure where/how/what you are going to interface in the swap but here's some more stuff, I'm a little bored.
    ADD VSV's connected.
    Alternator plug "EA1"
    Fuse box feed.
    Charging diagram from 03, same as 99/98 except for value of main "ALT" fuse.
    Pin out for "EA1"
    Some location info.
  9. Dec 31, 2017 at 3:01 PM
    madmax700r
    Washington
    Perfect!! Thank you
    The only thing I’d like to interface is my start circuit and charge curcuit because that’s the only thing my engine needs to run. I need to figure out if I can eliminate the gauge cluster without affecting my turn signals and headlights along with make sure my heater controls and everything else works independently.
  10. Dec 31, 2017 at 3:17 PM
    Dirty Pool
    99 XCAB V6 MT TRD
    More goodies along those lines.
    2 of 2
  11. Dec 31, 2017 at 3:29 PM
    madmax700r
    Washington
    Problem is I have no ecm anymore so going to have to figure out how to make everything trigger without it.
    I’ll see if I can wire the clutch start cancel to work still.
  12. Dec 31, 2017 at 3:31 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Oh man... the Haynes manual is about 10% as helpful as the factory service manual. For comparison this is how a Toyota wiring diagram looks like.
    The Toyota electrical FSM is like having a Lamborghini, and the Haynes wiring diagram is like a 1982 Trabant. Lol.
  13. Dec 31, 2017 at 3:36 PM
    madmax700r
    Washington
    Wow alright. I noticed that. Haynes sucks need the manual to wire this thing.
    Thanks for the info guys!
  14. Dec 31, 2017 at 3:37 PM
    madmax700r
    Washington
    Basically I need to wire the truck to make everything work while the engine, trans and ecm arent there... that’s how I have to wire it.
  15. Dec 31, 2017 at 3:41 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Tell me what year FSM you need and I can email it to you.
  16. Dec 31, 2017 at 3:45 PM
    madmax700r
    Washington
    Need one for a 1998 sr5 4x4.
    Found out when I pulled the rear axle out of it the truck was custom ordered cause on the door it has a ? Where the gear ratio code should be.
  17. Dec 31, 2017 at 3:46 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Really? Take a pic. That's rare
  18. Dec 31, 2017 at 4:12 PM
    madmax700r
    Washington
    Have a picture actually
  19. Jan 2, 2018 at 8:59 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Dirty Pool that truck is entirely to clean!!
