Wiring help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Utard, Aug 18, 2012.
  1. Aug 18, 2012 at 3:21 PM
    Utard
    Utard [OP] Well-Known Member
    Mark
    Nyssa, Oregon
    2012 DC LB 4WD TRD SPORT NAVI
    ------------------------------------------------------------ Stabilus.EZDown.Tailgate http://www.ezdown.com/home.php ----------------------------------------------- Tekonsha.Primus.IQ.Trailer.brake http://www.tekonsha.com/content/default.aspx---------------------------------------------------------------- Leer 180 CC http://www.leer.com/Truck-Caps#------------------------------------------------ Firestone Air Rite Air Bags--------------------------------------Kargomaster Rack
    I am putting in a air bag controller/compressor.
    It is saying to hook up to the "Un-fused side of the ignition powered auxiliary fuse". It will have a fuse for it own power so couldn't I just hook to the battery?
    Any one know where this is? Here is a photo of the fuse boxes.
    Its a 2012 if that matters.
    Thanks
  2. Aug 18, 2012 at 3:23 PM
    nfs257
    nfs257 Well-Known Member
    Menifee, Ca
    09 DCLB PreRunner MGM SR5 Debadged
    Trac Performance built Prerunner
    My Compressor is hooked straight to the battery with an inline fuse.
  3. Aug 18, 2012 at 3:33 PM
    Utard
    Mark
    Nyssa, Oregon
    My only concern with doing this is I got an air lift wireless air controller. If there was ever a problem in the air system it would run with the truck turned off and trash the battery.
    And I was thinking it might have a draw on the battery because it automatically keeps the air bags that the set psi.
  4. Aug 18, 2012 at 3:37 PM
    nfs257
    Menifee, Ca
    Ah I missed that run an add a circuit to the box under the dash behind the coin tray thing and run that to the relay and still run to the battery for your main power. That way only way power goes thru the relay is if ignition is on...
    Not sure where the wire less controller goes but I would guess where the switch is on this one.
  5. Aug 18, 2012 at 3:46 PM
    Utard
    Mark
    Nyssa, Oregon
    So would that be the same as using the "Un-fused side of the ignition powered auxiliary fuse" per what the installation diagram says to do?
    And is there one in the engine bay fuse boxes?
  6. Aug 18, 2012 at 3:49 PM
    nfs257
    Menifee, Ca
    I am not sure on the 12's but on my 09 I run all ignition powered on the box inside the cab.
    And the wording of that is confusing. Did they give you a diagram?
  7. Aug 18, 2012 at 3:59 PM
    Utard
    Mark
    Nyssa, Oregon
    I guess on the electrical schematic it just says "ignition source"? That means it wont have power it the key is out?
    So in the cab? What fuse # would be the best to tap into?
  8. Aug 18, 2012 at 6:46 PM
    nfs257
    Menifee, Ca
    An add a circuit has 2 fuses so whatever you tap into stays the same then your ignition wore to the relay would also be fused...
