Wiring help
Discussion in 'Technical Chat' started by single cab, Jan 9, 2015.
  1. Jan 9, 2015 at 5:55 AM
    single cab
    single cab [OP] Well-Known Member
    upstate ny
    2012 Single cab 4x4 mt
    I'm looking to set up 4 40 watt led pods on the front of my truck and I need a little help. I have 2 questions, first is how many relays should I use if I want them to turn on with the high beams? I have 2 lights and wont have the other 2 for a little while. Also what size wiring should I be using? Thanks
  2. Jan 9, 2015 at 6:22 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If they're all going to be controlled the same way (using a single switch and you do not want the ability to operate one pair separate from the other pair), then you only need one relay. As for wiring, I'd go 14 gauge at a minimum if using a 15 amp inline fuse. If you're using a larger fuse, you should upsize the wiring to make sure the wire can handle the capacity of the fuse (the fuse should always be the weakest link).
  3. Jan 9, 2015 at 12:33 PM
    single cab
    upstate ny
    I wasn't sure if one relay could support the 4 lights without any voltage drop and physically.
