Wiring help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Blktre, Mar 4, 2017.
  1. Mar 4, 2017 at 7:13 AM
    Blktre
    Blktre [OP] Well-Known Member
    Land of Oz....
    16 Super White DCLB TRDOR: The White Goat
    I'm planning a front LED light bar and 2 LED pods for the rear bumper with dual switches in the left cubby. I already have the ala @mattgecko LED bed lights installed. I wired those in direct from the battery with its own inline fuse at the battery.
    I don't want 3 separate inline fuses. But I can narrow it down to 2 I think. So I'm thinking I will wire in the bed lights into the rear pod's under the hood at a relay and use an inline fuse for the pod's and bed lights. Then another circuit for the front light bar with another relay and inline fuse. That leaves 2 inline fuses off the battery. That seems crowded. I'm not interested in splicing in power cables under the truck for the pod's using the existing power feeding the bed lights. To many splices even tho they will be soldered, silicone, and wrapped. That's also a PIA. So the pod's would have its own wire harness.
    I'm planning on using Mctune wire harness's for this project. My question(s), Is this a sound plan or is there a better way?
    Thanks......Cheers!
    boynoyce likes this.
  2. Mar 4, 2017 at 8:31 AM
    Sagebrush
    Sagebrush Well-Known Member
    Gens 1, 2, 3, and 4
    There is a better way.
    With this many circuits, I'd install a separate fuse box–there's a thread on this somewhere–run one heavy fused line from the battery to this new box and then connect each of your circuits to the box.
    Much cleaner.
    SB
  3. Mar 4, 2017 at 12:12 PM
    0210 Well-Known Member
    Vancouver, BC
    2016 TRD Sport Upgrade DCLB
    This. Run a 2AWG from the battery to a 100amp circuit breaker under the hood (grab one on Amazon for $40), then run the same wire back to the truck bed's cubby. Mount a 6-port BlueSea fuse box there, and connect the power wire to it. Then wire in all your rear accessories to the fuse box. Each will have a separate fuse and circuit, and you won't need to touch any OEM stuff.
    Powerprozeus, Haany4x4, Joe23 and 3 others like this.
  4. Mar 5, 2017 at 9:02 AM
    Blktre
    Land of Oz....
    Thanks. I will research this. Sounds like a way better solution plus I will have more space for other things down the road! Just what I was lookking for~
  5. Mar 5, 2017 at 9:07 AM
    Vancouver, BC
    CB: https://www.amazon.com/gp/product/B00139FQSS/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
    2 Guage wire pack (red/black) 10 feet each: https://www.amazon.com/gp/product/B0167K7DO2/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
    2 Guage wire (red) 25 ft: https://www.amazon.com/gp/product/B00KD2756W/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
    Terminals for the 2 guage wire: https://www.amazon.com/gp/product/B01K9MQKNO/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
    Crimp tool for the large terminals/wire: https://www.amazon.com/gp/product/B0002KR9MU/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
    Heat shrink: https://www.amazon.com/gp/product/B01CNPIK2O/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
    BlueSea fuse box: https://www.amazon.com/gp/product/B000THQ0CQ/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
    I pulled all these from my previous orders on Amazon (all are part of what I used on my own truck).
    Khrolar, boynoyce and stealthmode like this.
  6. Mar 5, 2017 at 9:11 AM
    Blktre
    Land of Oz....
    Beautiful @0210. You did all my work for me. I will add all this up and see if its easier to buy a few harness from McTune and use them with the circuit breaker and 6 fuse box. I really like doing it this way simply because its clean and done right for the long term.
    boynoyce, stealthmode and 0210 like this.
  7. Mar 5, 2017 at 9:13 AM
    Vancouver, BC
    Also grab this split loom: https://www.amazon.com/gp/product/B00H9L1N5O/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
    Any powered (positive) wire under the truck/hood should be inside this for physical protection.
  8. Mar 5, 2017 at 9:16 AM
    Blktre
    Land of Oz....
    This will be a fun project. And really not all that expensive for what you end up with.
  9. Mar 5, 2017 at 9:24 AM
    Blktre
    Land of Oz....
    Can I mount the circuit breaker under the hood and find a place for the 6port fuse box under the dash or hood and run accessory wire to the back of the truck and to the front light bar. Seems the fuse box doesn't need to be at the back of the truck. Or did I misunderstand you?
  10. Mar 6, 2017 at 9:02 AM
    Blktre
    Land of Oz....
    Just wondering. What is the purpose if the Bussman 100 amp breaker? If using a 6 port fuse block wouldn't that be sufficient for protection alone?
  11. Mar 6, 2017 at 9:06 AM
    Sagebrush
    Gens 1, 2, 3, and 4
    You need a fuse (or breaker) to protect the line from the battery to the fuse block and it needs to be as close to the battery as possible.
    SB
  12. Mar 6, 2017 at 9:11 AM
    VangaSTL
    VangaSTL Well-Known Member
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    Anyone know of a fuse box that also has relay slots in it?
  13. Mar 6, 2017 at 9:12 AM
    Blktre
    Land of Oz....
    Ok, thats what I was wondering. Of course. Thanks.
  14. Mar 6, 2017 at 9:23 AM
    axisofoil
    axisofoil Rocket Surgeon
    Gilbert, AZ
    2016 TRD OR Dcsb 4x2
  15. Mar 6, 2017 at 9:30 AM
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
  16. Mar 6, 2017 at 9:31 AM
    Broccoli
    Broccoli Well-Known Member
    Airdrie Alberta
    2016 trd sport blazing blue,
    Bussman rtmr. Theres a writeup in the forums search the above title^
  17. Mar 6, 2017 at 9:32 AM
    VangaSTL
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
  18. Mar 6, 2017 at 9:36 AM
    Broccoli
    Airdrie Alberta
    I just got a cheap fuse box from mictuning and a 5 pack of relays for 7$
    Put it in a small box and wired it all up. Inside the box is alittle messy but outside(whatyousee) is all clean:)
    If i did this again it would be a bluesea fuse box with ground terminals, or bussman rtmr
  19. Mar 6, 2017 at 9:55 AM
    Blktre
    Land of Oz....
    That Bussman rtmr is nice but pricey. I think the bluesea box and purchasing separate relays will do the same exact thing for half the money. Wire is cheap.
    axisofoil likes this.
  20. Mar 6, 2017 at 9:59 AM
    Blktre
    Land of Oz....
