Wiring Idenitifaction
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mikro, Jul 3, 2021.
  1. Jul 3, 2021 at 1:38 PM
    Mikro
    Mikro [OP] Well-Known Member
    2020 MGM TRD Pro
    I’m running the wires for a new LED light bar and when I popped the lower dash (under the steering wheel) I saw a connector with a yellow and beige connector free floating. I have no idea if it was connected to anything and if so, what.
    Any ideas?
    It’s dead center in the picture.
  2. Jul 3, 2021 at 3:30 PM
    robe689
    robe689 Well-Known Member
    Bob
    SE Connecticut
    2020 Silver Tacoma SR5 Access Cab V6 4WD
    Typically it's a good idea to send out a shout to @caribe makaira for these kind of questions.
  3. Jul 3, 2021 at 3:32 PM
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    Most likely a connector for an option that your truck doesn't have. Pretty common for all trim levels to come equipped with the same or similar wiring harnesses
    Thatbassguy likes this.
  4. Jul 3, 2021 at 3:36 PM
    caribe makaira
    Caribbean, Puerto Rico
    Clutch Start Switch connector.
  5. Jul 3, 2021 at 3:38 PM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Details on your light bar setup and wiring harness? Just to round things out and for my own curiosity.
    Thatbassguy and Grossomotto like this.
  6. Jul 3, 2021 at 3:38 PM
    AJKlug1
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Alright we've got a certified genius on our hands
  7. Jul 3, 2021 at 3:39 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Lt. Dangle, Thatbassguy and AJKlug1 like this.
  8. Jul 3, 2021 at 3:40 PM
    daveeasa
    David
    PNW
    But does he have matching 2 position 090IIU connectors like I do?:)
    @caribe makaira, is there anything at all useful we could do with this on an AT? I assume not.
    Grossomotto likes this.
  9. Jul 3, 2021 at 3:42 PM
    caribe makaira
    Nada...
    You could fool the system to start while in-gear, but that's what the Park/Neutral Switch prevents.
    daveeasa[QUOTED] likes this.
  10. Jul 3, 2021 at 4:00 PM
    Mikro
    2020 MGM TRD Pro
    Thank you! I have an automatic so that makes sense.
  11. Jul 3, 2021 at 4:04 PM
    Mikro
    2020 MGM TRD Pro
    I have a 20” Rough Country light bar mounted in a Body Armor Hiline bumper. The wiring harness came with the light bar, but I used an “OEM” switch from Cali Raised LED.
  12. Jul 3, 2021 at 4:04 PM
    caribe makaira
    :hattip:
  13. Jul 3, 2021 at 4:07 PM
    daveeasa
    David
    PNW
    And it has a backlight? Or no backlight?
    This is the one I did for @ljh824 so he could use his zombie switch. Just curious how you did yours and if there are some good ideas I might consider for next time as I’m doing something for @Zumozuzu7 right now.
  14. Jul 3, 2021 at 4:12 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    technically I can buy a clutch start stop switch and connect it to that connector and act like I have a manual transmission.
    looks like I know what I'm doing this weekend
    daveeasa likes this.
  15. Jul 3, 2021 at 4:18 PM
    caribe makaira
    :bananadead::bananadead::bananadead:
  16. Jul 3, 2021 at 4:56 PM
    robe689
    Bob
    SE Connecticut
    @caribe makaira - Thank you so much for answering @Mikro's question. I saw a lot of views and no answers to his question.
    I am always amazed (but never surprised) at how quickly and accurate your responses are to our questions. :bowdown:
  17. Jul 3, 2021 at 4:59 PM
    Mikro
    2020 MGM TRD Pro
    It has a backlight while the switch is on. I could have had a dim backlight while switch is off and headlights are on, but that would have required me to tap into another wire, and that is WAAYYY above my capabilities. I was struggling with the butt connectors and crimping, etc. the wires from the switch to the light bar harness.
    What you have there is impressive and looks like I could have used something like that and it would have made my day MUCH easier.
  18. Jul 3, 2021 at 5:15 PM
    daveeasa
    David
    PNW
    Gotchya. Was the original switch a two way oval rocker?
    If you need switch illumination, @kmorgan3 has that covered.
  19. Jul 3, 2021 at 5:47 PM
    Mikro
    2020 MGM TRD Pro
    It was similar, but a push button. Pic below
  20. Jul 3, 2021 at 5:58 PM
    daveeasa
    David
    PNW
    Wow that is severely sucky. Good move switching out the switch
