Wiring in bed lamps
Discussion in 'Lighting' started by hogeyphenogey, May 22, 2014.
  1. May 22, 2014 at 3:52 AM
    hogeyphenogey
    hogeyphenogey [OP] Back in a Tacoma
    Dave
    Agawam, MA
    Lunar Rock 2023 TRD Sport 6spd
    I'm thinking of adding some small lamps into the two bed pockets and I recently took my 7 pin trailer harness down to a 4 pin and ran that up through the large stoarge bin on the left side. This left a black power wire that I capped off and is unused. Can I simply tie a switch into that wire, then to the lamps? Since I'd be using a driving lamp kit it should come with an in line fuse.
    Am I right? Any suggestions?
  2. May 26, 2014 at 4:40 AM
    hogeyphenogey
    Dave
    Agawam, MA
  3. Jun 13, 2014 at 5:44 PM
    hogeyphenogey
    Dave
    Agawam, MA
    I hear crickets.... No-one with any thoughts? I'm not the best with electrical, so... Any help is appreciated.
  4. Jun 13, 2014 at 5:45 PM
    hogeyphenogey
    Dave
    Agawam, MA
    The black wire was the always on wire from the 7pin connector.
  5. Jun 13, 2014 at 6:07 PM
    ShrimpTaco
    ShrimpTaco Lounge Lizard
    Blue Gecko Cantina
    '07 TRD Off Road AC PreRunner
    You are correct that the black is 12 volt power but it is only hot when the key is in the acc position in the ignition. So if you don't mind digging your keys out every time you need the bed lights then yes you can.
  6. Jun 15, 2014 at 2:39 PM
    hogeyphenogey
    Dave
    Agawam, MA
    That's for the confirmation!
