Wiring Information
Discussion in '2nd Gen. Tacomas (2005-2015)' started by H0LLYW00D, Oct 4, 2010.
  1. Oct 4, 2010 at 9:17 PM
    H0LLYW00D
    H0LLYW00D [OP] Well-Known Member
    I am looking at getting a module that will flash the brakes 4-6 times before they go solid for the rear brake lights, which I am hoping to wire up to the third brake light as well, does anyone know where the third brake light connected into the brake harness? If i can splice into the wiring before they goto each light it would be easier than trying to splice into each one separatly. the other option is to not include the third brake but I think it might look funny.
    Also I am getting a module that would flash the signal lights 4-6 times with a soft touch of the lever for lane changes. So I'm curious to know if anyone has the wiring for the signal lights as well.
    Thanks
  2. Oct 4, 2010 at 9:22 PM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    There is a module for motorcycles you can use. Its been done before try searching.
  3. Oct 4, 2010 at 9:28 PM
    H0LLYW00D
    I have found The module just curious how hard they are to wire. I do t want to make a rats nest of my wiring harness as I do all my electrical mods.
  4. Oct 4, 2010 at 9:31 PM
    borderbrat
    Jeremy
    Victoria BC, Canada
  5. Oct 5, 2010 at 4:02 AM
    H0LLYW00D
    Which would look better:
    1) no flashing at all
    2) 3rd brake light only
    3) left and right brake lights only
    4) left, right and 3rd brake lights
  6. Oct 5, 2010 at 4:44 AM
    Mark C.
    Mark C. If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
    X2 ....I've been contemplating the 3rd brakelight flashing mod.
