Wiring issue or bad relay ?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tycoma98, Sep 4, 2020.
  1. Sep 5, 2020 at 4:30 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Looking over everything more carefully, if you pull one tail light bulb at a time can you get rid of the issue - not sure if that’s a feasible route to diagnose if it’s a faulty socket or bulb, but now it looks like you need to find the place where power’s transferring from the headlights / tail lights to the blinker and it could be in the tail light circuit since you followed the advice to remove the tail light fuse and the issue went away.
  2. Sep 5, 2020 at 4:58 PM
    Tycoma98
    Tycoma98 [OP] Active Member
    Tyler
    1998 white tacoma 4x4
    The tail lights only have a replaceable reverse bulb and
  3. Sep 5, 2020 at 4:59 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Yes, the corner lights are powered by the Tail Light fuse.
    If by pulling the tail light fuse, your turn signals works correctly, that tells us the problem is in the tail light circuit. Do you have trailer wiring?
    Dalandser likes this.
  4. Sep 7, 2020 at 6:23 PM
    Tycoma98
    Tyler
    Yes I have trailer wiring but I’ve checked over all that and everything seems fine with it
  5. Sep 7, 2020 at 6:42 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    It wouldn’t hurt to inspect the wiring harness all the way back to the lights.
    TnShooter likes this.
  6. Sep 9, 2020 at 2:26 AM
    Tycoma98
    Tyler
    Bad thing is I’ve already checked it from tail lights to under dash
  7. Sep 9, 2020 at 2:35 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    That's good - it's one less spot it could be feeding power. Keep looking through the harness and taking apart connectors like the one under the driver's seat if you already haven't. I'm guessing next up would be the switch / steering column wiring but if you don't find it out I have a 98 wiring FSM.
  8. Sep 9, 2020 at 2:48 AM
    Tacoma Mike
    Southern Maine
    Looking at it means nothing.
    Unhook it from the truck.
    98% of the time it’s a short internally in the box.
    Anytime I have one of these I cut the box out and it fixes it.
    The other 2% it was installed like crap and was going to fail soon anyways.
    frizzman and TnShooter like this.
  9. Sep 9, 2020 at 12:04 PM
    Tycoma98
    Tyler
    Okay so the trailer wiring harness, is that just that extra wiring harness in tail light ?
  10. Sep 9, 2020 at 2:58 PM
    Tacoma Mike
    Southern Maine
    The wires from the box to the tail lights yes. Unhook those input wires and try the systems
  11. Sep 9, 2020 at 3:03 PM
    Tacoma Mike
    Southern Maine
    People wire those things up all sorts of ways.
    So any extra connections in the tail lamps disconnect
  12. Sep 9, 2020 at 9:55 PM
    Tycoma98
    Tyler
    Did that and boom works so I just unhooked the whole harness
    TnShooter and Dalandser like this.
  13. Sep 10, 2020 at 1:39 AM
    Tacoma Mike
    Southern Maine
    Yeup
  14. Sep 10, 2020 at 8:03 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
  15. Sep 10, 2020 at 9:33 AM
    #35
    Tacoma Mike
    Southern Maine
  16. Sep 10, 2020 at 2:15 PM
    #36
    Black DOG Lila
    Virginia
